Simplicity 6500 Series
   / Simplicity 6500 Series #1
MerlinJerry
I have a nice tractor which is probably about a 1989. I would like to research for possible equipment. I have a worn out 30 inch "off set" rototiller which attaches to the back right side of the tractor. I believe the unit is worn out because it hangs up and burns the belt unless I am quick enough to disengage it.
I also have the 48 inch three blade mowing deck and a dozer blade. The only thing I have really used in the 13 years I have owned the unit is the roto tiller and hauling a small trailer.
The tractor runs great and needs to have the starter rebuilt or replaced because it drags.
If I can get the rototiller going I might keep the unit, otherwise I will sell what I can. I am located is Southern Oregon so any thing I get would probably need to be shipped. Any ideas would be appreciated.
Thanks for your post. I tried the ref and they have no tiller or attachment items according to search results.
   / Simplicity 6500 Series #4
I don't like doing this, since that is my site, but... there's many different attachments for a 6000 series Simplicity. See this attachment catalog -- not everything fits, but many do. Look at the specifics for the ones you might be interested in:
1982 Attachments
Thanks for the post. I didn't see an offset tiller which covers the right hand wheel tracks. My unit uses a jackshaft to atach the tiller with belts.
FYI. My virus check says there is a threat on file name Sample. The threat name is Exploit Script injection-364 I don't know any more than what my virus checker told me.
Sorry but some of the previous was lost. file name should have read simpletractors.com/jbsx/sample/asp
   / Simplicity 6500 Series #7
See the note in grey on www.simpletractors.com
AVG is throwing you a false alarm...
Thanks. Ican believe that.
2018 Caterpillar 308E2 CR Midi Excavator (A52377)
2018 Caterpillar...
Freighliner Tender Truck (A55301)
Freighliner Tender...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
2017 Rogator RG1300B Dry Fertilizer Applicator (A55302)
2017 Rogator...
2012 PETERBILT 388 DAYCAB (A53843)
2012 PETERBILT 388...
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
