Dealer 5425 On Dealer Lot
   / 5425 On Dealer Lot #1
downslope
NY
MF TO-35, Ford(s) 2000, 8N, 9N, White 2-70, NH TD75D, JD 5045D
I've seen a new open station FWD 5425 on local dealer's lot. It has 3 remotes in the middle, two at the back and a power reverser transmission. The tires are 28" R-1, no weights. How much do you think I should expect to pay for this configuration? It's now considered a prior model, is that right, replaced by the 5 series? Which of the new 5 series would configure closest to this particular 5425?
   / 5425 On Dealer Lot #2
all depends on where you live. is this a rental return perhaps or does it have 0 hours? comparible 5 series tractor would be a 5075M.
Not a rental return, it is zero hours.
   / 5425 On Dealer Lot #4
How much are they asking?
D.
D.
They are asking what I think is too high, in the high $30's way beyond $35K.
I may be wrong, but I would think that kind of price would be more in line with a cab 5425. I only inquired briefly when I stopped in to order some parts. The salesperson did indicate a willingness to compete to some extent with other makes in the area and suggested I come back and see the manager who was out that day.
We have several other brands around but the next JD is over 100 miles. I could probably get a Kubota 7040 equipped similar in the $29K range, maybe a little less for an equivalent NH TD or CaseIH Farmall. I was thinking the open station JD should be in the low $30's not the high end of that decade. I suppose I can always make an offer if I don't pick up something else.
   / 5425 On Dealer Lot #6
High 30s seems way out of line.
I bought my 2005 JD 5525 cab 4wd for $41K new.
D.
   / 5425 On Dealer Lot #7
The 5075M configured as closely as I can to the OP's description of the 5425 is $40,495.
   / 5425 On Dealer Lot #8
This should help a bit--In Aug 08 I bot 5325, open station, 4wd, 3 remote back, 522 loader, power reverser 12x12 for 37,100. The third remote was added at the dealer. The 5325 has a different motor than the 5425. I priced 5425 at the time, but, sorry, I can't remember the difference in the two models.
   / 5425 On Dealer Lot #9
If I'm not mistaken, it was about a $1,300 to $1,700 jump in price to the next step. Might have been a bit more between the 5325 and the 5425 versus the 5425 and 5525.
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51573)
IMPORTANT PLEASE...
1989 Freightliner Cabover FLA086 (A52128)
1989 Freightliner...
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
2018 Toyota RAV4 SUV (A50324)
2018 Toyota RAV4...
2016 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51242)
2016 CATERPILLAR...
