Pressure washer detergent -- is it worth using?
   / Pressure washer detergent -- is it worth using? #1
jas67
Central PA
Kubota B7610 + Kubota G1800-S
I bought a used pressure washer. It is an older Huskey-branded 11HP briggs L-head powered unit. It works great, but the detergent valve is damaged.
Is it worth using detergent with a pressure washer, or is it just as good, or better to just spray on bleach or other detergent appropriate to the particular job with a weed sprayer, let is soak, and then it it with the pressure washer.
Thanks!
Jay
   / Pressure washer detergent -- is it worth using? #2
I think your method would work as well as what my washer does as far a spraying on soap goes.
   / Pressure washer detergent -- is it worth using? #3
Either way is good. A soap injector shouldnt be that expensive.
I use the injector for diluted degreaser or car wash, and keep a more concentrated mix of purple degreaser in the bug sprayer.
   / Pressure washer detergent -- is it worth using? #4
I was disappointed to learn that most pressure washers will not dispense soap under pressure like at a car wash, they will only spray a *no pressure mist of soap solution when fitted with the largest orifice nozzle.. So your results spraying on soap with a weed sprayer would be comparable.
*I assume the soap solution is drawn into the washer by a venturi tube (similar to a carbeurator) operating on the bernoulli principle, where higher fluid flow results in a lower pressure, thus creating a vacumn to draw in the soap solution. When a high pressure nozzle is fitted, either the flow is reduced or the pressure increased so that soap solution will not pull into the pump/pressure washer.
   / Pressure washer detergent -- is it worth using? #5
Correct- a higher pressure stops the soap on mine. When my adjustable nozzle is wide open (low pressure) is when it draws soap, when returned to a jet or fan the soap stops.
Personally I've found the ability to add soap/detergent/whatever near useless, doing it with a seperate sprayer works just as well and is more controllable IMO.
   / Pressure washer detergent -- is it worth using? #6
I'll second that.
I'm fortunate to have a diesel burning hot water pressure washer which often makes any detergent unnecessary. If there is a thick layer of fresh grease however, it is very good at splattering the grease everywhere - detergent or not.
I'll second that.
LOL! I used the pressure washer yesterday, and while it did a great job of cleaning my siding and brick walkway on the north side of my house (with gets very little sun, and had lots black mold, and green algae-looking slime), it also does splatter the stuff on anything else around. I have a brick front porch (that also had said green & black stuff on it), with some inside corners that you can't really clean without the deflecting "stuff" all over the side of the house. I ended up spraying the ways downward with a fan spray, and then squeegeeing it off the porch.
Anyway, thanks for all the advice. Yes, the valve is only about $15-$30, but I didn't want to bother if it wasn't going to be worth it -- I already have the weed & bug sprayer.
TBN is such a great resource of knowledge!
   / Pressure washer detergent -- is it worth using? #8
FYI, you can spray soap at high pressure using a "Upstream Injector". I thought about getting one, but due to the fact that most time i use a caustic degreaser, i didnt want that chemical in my pump. I understand that alot of people do it with no effects, and i may still.
   / Pressure washer detergent -- is it worth using? #9
I am afraid using soap is a waste of time and money. I'd have to see it work to believe in it.
   / Pressure washer detergent -- is it worth using? #10
not a waste of time. Check out all the industrial wash guys, they all use soap injection.
BLACK DIAMOND AIR COMPRESSOR (A53843)
BLACK DIAMOND AIR...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
Year: 2013 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 79843.5 Plate: Body Type: 4 (A53422)
Year: 2013 Make...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A54811)
2015 Toro Multi...
Heritage HC72 Rotary cutter (A53473)
Heritage HC72...
1987 CASE IH 9150 TRACTOR (A53843)
1987 CASE IH 9150...
