Cultipacker vs Pulverizer
   / Cultipacker vs Pulverizer #1
N80
Super Member
SC
Kubota L4400 4wd w/LA 703 FEL
I need something to help prepare my corn seedbed. I plow and then I disk but I'm still often left with lots of clods. The clods make it hard to push my hand planter along (its one of those Earthway type planters). This led to a lot of bouncing and fits and starts that in turn led to uneven seed depth and even a lot of gaps.
I think something live a cultipacker would be ideal for this job but I can't really afford one. But, I know a guy with a pulverizer who might be willing to let it go cheap. It is sort of like this:
But, its a Landpride (not a Leinbach) and it is in decent shape although it is only 5 feet and my rears are at about 6 feet.
Anyway, would a pulverizer function in this capacity? Or would it pack the soil to tightly? And what would a 5' Landpride pulverizer be worth?
I do realize that it probably wouldn't function the way a cultipacker does in regard to pulling it over clover or grass seed that you just spread.
Any assistance would be appreciated. Thanks.
   / Cultipacker vs Pulverizer #2
2 different animals..... The pulverizer is more of a grading tool. (finish grading) To use the pulverizer in the "farm tool" mode, you'd need relatively "clean" ground. ie, no stalks, clumps of sod, crop residue, ect. That'll clog it up in a hurry.
But....Pulverizer has many other uses. Could be a value later on too... They're GREAT for grading gravel roads by the way. In a pinch, I suppose you could use it for your intended purpose, but a real compromise. If it's cheap enough, buy it, use it, and then re-sell later if you don't like it. They generally sell fairly good.
   / Cultipacker vs Pulverizer #3
OK....I'll give a shot at a response. For your purposes (corn) I think that the machine shown would work fine for leveling and breaking up clods and such....maybe he will let you have a test drive?? :D Generally the implement shown is used by contractors prior to seeding for lawns. I believe these are generally much more expensive implements that an old cultipacker....so if you can get it for a good price I think you should go for it. However it wont be much value for packing seeds....such as the cultipacker would.... IMO.
Thanks guys. I think Leinbach even calls it a "yard tool". In any case, I checked today and it was gone.
It sounds like a cultipacker is exactly what I need but I can hardly justify the cost of one. If I find one cheap I might pick it up. Got any home brewed ideas for busting up tough clay clods?
   / Cultipacker vs Pulverizer #5
leinbach makes a cultipacker that is 3ph you might look at. Also either this site or QDMA had a make your own cultipacker post that was economical.
   / Cultipacker vs Pulverizer #6
I'd rig up some type of heavy drag (big log, heavy piece of metal pipe, etc) and hitch it to the disc--kill 2 birds with one stone.
   / Cultipacker vs Pulverizer #7
I put a WTB on Craigs List for a cultipacker. After a few weeks I got one call with a for sale....bought a 7 footer for $175. I have heard of quite a few people buy 'em for $100 to $250.
Also if you do a search....there is a new hollow plastic type cultipacker being made for about $250. plus shipping. I saw it at QDMA.com Looks to be a fair unit which would stand up to moderate use....but if you can find an oldie made from iron.....they are still better IMO. :)
I've tried the log (6x6 post) and the chain link fence. They work fine as harrows for covering seed, but not too good on the clods.
What I have done, which works modestly well, is just to run over the whole plot with the tractor tires. Its tedious, wastes fuel and isn't practical for large areas, but works in a pinch for a small plot.
   / Cultipacker vs Pulverizer #9
Don't laugh at the size of my operation here, but I did find that my chain harrow broke up clods better than I thought it would.
I would not laugh at the size of the operation, but I sure wish I had your dirt. My dirt has a lot of clay in it and those clods are very hard to deal with even after a good many passes with the disk....which starts to compact things a good bit so I try not to do too many passes.
The corn grows very well in my soil so that really isn't the main problem. The problem is pushing that hand planter through the rocks and clods. Maybe the solution is just to buy a 3pt planter! Of course, I'm not sure how a real planter would handle the clods either. Planting by hand worked just fine last year, but talk about a tedious two man job!
I think a big part of my problem is also timing. If it is too dry the clods are like rocks and hard to break up. If it is too wet that are like lumps of clay. The disk might slice them, but doesn't really break them up. From past experience it seems like when the moisture content is just right the disk breaks the clods up a lot better. I just don't have a good sense of when just right is. Learning that will probably be more valuable than a cultipacker or harrow.
2013 International DuraStar 4400 Altec AM547 50FT Material Handling Insulated Forestry Bucket Truck (A51692)
2013 International...
2015 GMC SIERRA 2500 SERVICE TRUCK (A52576)
2015 GMC SIERRA...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
