Spacing of rear wheel
   / Spacing of rear wheel #1
joe swanson
Adirondack Mts, Fulton County , NY
YM 336D
I took delivery of my 336D this week and the rear wheels are spaced 46" center to center. My prooerty is quite hilly and uneven. The Rims are adjustible and I can pick up a few inches by doing so.
My question is can the Rims be reversed as well. Seems I could pick up quite a bit more spacing if this is possible,
Thanks
Joe
   / Spacing of rear wheel #5
I recommend make sure your wheel discs are dished outward plus you may be able to swap the rims/tires to opposite side and gain some more width.
For some applications wheel weights (preferred) or ballast in the tires is also needed. I found 50% fill on these oversize tires was all it would take before it was too heavy to go uphill in the higher gears. And get a ROPS is you don't have one!
The previous owner of my Yanmar put on oversize tires and rims that give it 5 ft overall width. I can't imagine going down in the back of my orchard with anything narrower.
   / Spacing of rear wheel #6
California I can't imagine going down that on mine at all with the loader on it.
   / Spacing of rear wheel #7
Joe, it would surprise me if the front axle did not pivot on your tractor. So if you jack it up to swap tires don't do it with one jack under the rear as both ends of the tractor will be on pivot points. OH YEAH, been there with much larger tire.
   / Spacing of rear wheel #8
If you turn your front rims outward please remember us when you need front end parts. Not designed for that, while the rears are.
Thanks to all for the good info. I am not planing on reversing the front wheels I don't think there is anything to begained. The rear are getting moved to pick up the maximum width. I have a hoe and front end loader on this and jacking it isn't a problem.
Thanks
Again
Joe
   / Spacing of rear wheel #10
I thought somebody might like that picture! Here are a couple more from Saturday.
The back of my orchard was made in terraces where it got too steep, and that slope is the access to the last two terraces. After heavy herbicide use was abandoned a few years ago, these old apple trees became choked with blackberry bushes. I am gradually digging out the blackberry jungle and getting the trees accessible for harvest. I'm also discing the poison oak that has gotten a start under the eucalyptus.
I can't imagine going down there without a ROPS but that's the way it was done over the past 90 years. Maximum wheel weights plus loaded tires are standard for the sloping orchards around here. And the 3-point disc adds a lot of weight low down. Still, I crawl in low2 so I can feel every twig I drive over!
And finally a more rational picture from Saturday. I'm discing the narrow corridor between my last orchard row and the row of steel rods delineating the boundary of the new vineyard next door.
2025 CFG Industrial H15R (A50123)
2025 CFG...
1998 Volvo VNL64T Sleeper Truck (A52384)
1998 Volvo VNL64T...
2015 FORD E350 16FT BOX TRUCK (A53426)
2015 FORD E350...
1996 Timpte 46ft Hopper (A53473)
1996 Timpte 46ft...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
