Oil & Fuel CK30 oil leak help needed
/ CK30 oil leak help needed #1
Jerek
South France
Kioti ck30 HST
Bought a second hand CK30 with 215 hrs. on the clock. It had been standing for several months unused in the UK outside. When it was collected by the transporters an oil leak developed from the enfgine. When it arrived here in the south of France. I topped it up and started it to get it off the transporter and the oil just spurted out within a few seconds there was a massive pool. Cannot see exactly where it is coming from but somewhere above the oil filter. The flow is so great as tho' a pipe has burst. Any ideas how to progress with the repair. Seller denies any knowledge saying it left him OK. So its up to me to repair it.
Jerek
/ CK30 oil leak help needed #2
Can you tell if it's engine lube oil or hydraulic oil?
There is a small rubber cap on the injection pump for filling the engine with oil, make sure that's in place.
/ CK30 oil leak help needed #3
There are several high pressure oil pipes and hoses in that area. The hydraulic pump, the fuel injection pump, the oil filter, etc.
Don't run the engine until you find it.
/ CK30 oil leak help needed #4
I wonder what the odds are that their are 2 o-rings on the oil filter??
Sometimes when you change the oil, the old seal sticks to the engine and when you put the new one on you have two seals and will cause it to leak really bad.
Its easy to just spin the filter off and check.
I have found the problem! Took of the oil filter and washed it out with petrol before I was going to put it back when I noticed the petrol leaking out of the filter. On closer examination there was pin hole in the side. I made a tempory seal with a self tapping srew. Refilled with oil and started the engine. Voila no oil leak! There was a rust stain on the area concerned and I think that while the tractor was standing water had collected on the filter and rusted partially through. So when I tested the tractor it did not leak. But it had to be driven some distance to be loaded and during this trip the oil pressure must have finished the job. A great releif! Just hope no other damage has occured. I am off to the dealer tomorrow for a full set of filters and replacement oils in case any of the other systems have been contaminated with water ingress.
/ CK30 oil leak help needed #6
Looks like an easy fix. The CK30 engine holds 6 quarts of oil, so unless a good bit was pumped out, you should be good.
/ CK30 oil leak help needed #7
My Ck30 sat outside in the rain for the first couple of years I owned it, many sit outside on dealer's lots for years too. That's OK. The ignition switch is also a weak point if the little plastic cover was not deployed and water got in.
/ CK30 oil leak help needed #8
Bought a second hand CK30 with 215 hrs. on the clock. It had been standing for several months unused in the UK outside. When it was collected by the transporters an oil leak developed from the engine. When it arrived here in the south of France.
Jerek
So where in France? How scattered are the Kioti dealers in Europe? Does this mean that if I tour Europe wearing my Kioti cap I'll blend in with the local countrymen ;)
Kinda impressive to see Kioti's global footprint. What's their global market share?
I live in the South of France near Perpignan on the Spanish border. Fortunately the nearest dealer is in just in Spain. They are cheaper and more busness like over there! Changed filters and all in working well - so far.
/ CK30 oil leak help needed #11
Great that's all it was, I had the same thing happen on my old truck, and it did not take long for the filter to rust through, probably less than six months. I put low miles on the truck but I wouldn't have gone more than six months or so without an oil and filter change.
Joel
UNUSED FUTURE FT36C STAND ON SKID STEER (A52706)
UNUSED FUTURE...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
HOMEADE 8' X 22' TRI-AXLE TRAILER (A60430)
HOMEADE 8' X 22'...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A61307)
2022 Schulte...
Year: 2015 Make: Ram Model: 5500 Chassis Vehicle Type: Truck Mileage: Plate: Body Type: 2 Door Cab; (A55852)
Year: 2015 Make...
BUNDLE OF 1 1/2"X1 1/2"X79" TUBING (A60430)
BUNDLE OF 1 1/2"X1...
