MF 150 GAS
   / MF 150 GAS #1
mayer2323
Member
Whats your take on a 150 gas I know the 150D gets good press but I am going to look at a 150G that there asking 3500 for with no loader . The price sounds good hope it looks and runs good.
   / MF 150 GAS #2
The engine in the 150 gasser is a Continental 3 cyl if it's a 1964-68 model. It's a Perkins gasser from 1969-74.
I check availability of parts before buying a 40+ year old tractor. The engine rebuild kit is available
Massey Ferguson Engine Overhaul Kits
In Jul06 I bought a 1964 MF-135 diesel with Multipower for $3600 (no FEL). It had sheet metal damage, but the engine runs OK. Has a few oil leaks now that I need to fix.
The average trade-in value (what a dealer would give) of that 150G runs from $1300 (1964 model) to $1900 (1974 model). The average resale value (what a dealer gets on resale) ranges from $2600 to $4000.
   / MF 150 GAS #3
The Continental gasser is a FOUR cylinder engine. Perkins gasser is three. The Continental is 145 cu in, the Perkins is 153, and shares many parts with the diesel.
Parts for EITHER engine are cheap (relative to most other engines) easy to get, and they're BOTH very simple engines to maintain.
Neither hold an advantage over the other. Both EXTREMELY good engines as far as power output, longevity, ease of maint/operation.
150 gassers generally sell in the same ballpark as a diesel, SLIGHT advantage to the diesel. Around here, you'd expect to pay $3800 to $4500 for an average to slightly better than average 150 gasser. Parts for the tractor itself are a breeze to get ahold of. Massey Ferguson "HERITAGE PARTS" carry a complete line for that tractor. Lots of aftermarket stuff too. MOST of the tractor is essentially the same as a 135. There's so many of them still on the job, parts vendors bend over backwards to accomodate anyone needing help.
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
2019 FORD F-650 SUPER DUTY BOX TRUCK (A51406)
2019 FORD F-650...
HANG ON 48" CATERPILLAR FORKS (A51242)
HANG ON 48"...
2011 Mack CHU613 T/A Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
2008 John Deere 6330 Premium with Trebro Sod Harvester (A52128)
2008 John Deere...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
