Need help selecting hydraulic fittings
   / Need help selecting hydraulic fittings #1
Knight
CT
Kubota L3400
I bought a side link cylinder from SC with Sae 8 ports
I need a 90 degree fitting into 1/4" Hydraulic hose.
   / Need help selecting hydraulic fittings #2
Knight,
What is your question? A quick look at DHH does not have SAE8 90* fitting with 1/4" hose. So then decide if you want a 90* hose fitting with a straight adapter or a 90* adaptor with a straight hose fitting. I would go with which ever comes out cheapest. Or go to a local guy and ask what he has to make the connections. His stock may determine which way you go. Also he might have a 90* hose fitting with and SAE8 end.
   / Need help selecting hydraulic fittings #3
I don't know if you're going to find a 1/4" hose end with a #8 SAE 90ï½°, so your simplest alternative is to use a female JIC hose end with a JIC x SAE adapter. The major question is whether you want to put the 90° on the hose end or the adapter.
Option 1: FJX-04-04 (1/4" straight JIC hose fitting) and 6801-04-08 (1/4" JIC x #8 SAE 90°).
Option 2: FJX90-04-04 (1/4" JIC 90° hose fitting) and 6400-04-08 (1/4" JIC x #8 SAE straight).
You can order them online at DiscountHydraulicHose.com or, if these are the only parts you need, you can save the shipping charges and pick them up at your local hydraulic hose shop.
Ken
   / Need help selecting hydraulic fittings #4
Option 3. Get a 90 degree -8 ORB X -6 JIC and get a -6 JIC female put on your -4 hydraulic hose.
I'm pretty sure DHH stocks these. If you have 100R2AT hose you can get a field attachable hose fitting from them too.
Andy
2014 Ford Transit Connect XLT Cargo Van (A55852)
2014 Ford Transit...
1998 FREIGHTLINER FL50 SPORT CHASSIS (A56129)
1998 FREIGHTLINER...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A53421)
2025 JMR 40in...
Lockwood 480 Pecan Harvester (A55315)
Lockwood 480 Pecan...
