MF 1532 Front Diff. question
   / MF 1532 Front Diff. question #1
jwillett
China Grove, NC / Wagener, SC
MF 1532
Are the front axles locked like a spool or are they open diff's. The other day I was moving some old fire wood around with the FEL and was in some pretty slick mud. I noticed that the left front tire would spin and the right would not, tractor was almost stopped by the firewood at this point. I did have the rear diff locked at this point. Just wondering if I have a problem as I thought it was totally locked in the front.
Thanks,
Jim
   / MF 1532 Front Diff. question #2
You do not have a problem with the tractor.
All front wheel assist tractors will do this. When you lock the back wheels and place the tractor in 4 wheel drive...you essentially have a 3 wheel drive tractor.
   / MF 1532 Front Diff. question #3
Right, the front axle is a standard type differential, just ring gear and pinion, spider gears and axle gears, no locking mechanism, no positive traction device.
jp
John Deere 1025R (A53317)
John Deere 1025R...
2007 FORD F-150XL TRITON TRUCK (A51406)
2007 FORD F-150XL...
PALLET OF TIRES & GAS BOTTLE (A58374)
PALLET OF TIRES &...
2003 Freightliner FL60 American LaFrance Ambulance (A56858)
2003 Freightliner...
Eaton PRS0100001 145psi Rotary Screw Air Compressor (A56857)
Eaton PRS0100001...
GRILL GUARD & POOL LADDER (A58374)
GRILL GUARD & POOL...
