Can NOT install driveline onto PTO..
   / Can NOT install driveline onto PTO.. #2
Are you sure the collar goes forward and not the other way. Hold the pto shaft up and look into the end while you slide the collar. watch for the detent to retract to know which way it works. Sometimes they are juwst tight for a while and a wire brush or a little sand paper folled by some spray grease will help. Good luck.
Andy
MADE in CHINA POS collar. Took it apart and removed SEVERAL metal chips.
Works fine now.
FN in MT
   / Can NOT install driveline onto PTO.. #4
Works fine now.
FN in MT
I know what you mean. The gear box shaft on my Chinese RFM were about .006 too large for the coupling. I had to file the splines down just to slip it on!
2016 Volvo A25G 20CuYd Articulated Dump Truck (A49346)
2016 Volvo A25G...
2019 POLARIS RANGER XP PROSTAR 900 HD DOHC UTV (A51406)
2019 POLARIS...
71057 (A49346)
71057 (A49346)
2019 New Holland C227 Skid Steer (A50657)
2019 New Holland...
2002 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2002 Ford F-150...
5K ANNULAR BLOWOUT PREVENTER (A50854)
5K ANNULAR BLOWOUT...
