Removing sterring wheel from my Kubota
   / Removing sterring wheel from my Kubota #1
banjerpicker
Member
I have a L2850 and a M4700. Both shop manuals call for using the same steering wheel puller...over $250.00(ouch!!!) from Kubota.
Do you have to use one? Or cheaper models that would work from a car dealer, parts house or even a rental place?
I just need some ideas to help get this wheel off so I can get to the front panel wiring.
Thanks Larry
   / Removing sterring wheel from my Kubota #2
Thanks Larry
I've pulled the steering wheel off one of my B5100E's with a Sykes-Pickavant puller, sadly I cant recall whether I used the thee legs or the bearing seperator.
A seperator, if it fits, would spread the strain over a bigger area.
   / Removing sterring wheel from my Kubota #3
I recently pulled the steering wheel off my B7100HST-E and all I had to do was remove the center cap,nut and washer and tapped underneath with a 4 lb. hammer lightly, while pulling up on the outer edge and in a couple of licks, it came right off.I dont know if you have room to get underneath it like that, but mine was no problem. Also I dont see why a regular steering wheel puller, like from a parts store would not work. Also before replacing it back on , put some anti seize on the splines and threads to make it easier next time. Good luck, zman
2025 K731G UNUSED Flower Bed (A53117)
2025 K731G UNUSED...
2018 HINO CONVENTIONAL TYPE TRUCK (A52472)
2018 HINO...
Bobcat 873 2sp Skidsteer (A52384)
Bobcat 873 2sp...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
JLG E300AJ (A50123)
JLG E300AJ (A50123)
