What to use to remove Sage Brushes???
   / What to use to remove Sage Brushes??? #1
chazzy
I have about 2 acres of field that are densely covered by thick grown sage brushes having stem/root diameter of 1" to 1.5" and height upto 4'. I am about to buy a 30-hp hst driven compact tractor with FEL, 66" box blade & rotary cutter.
Questions are:
> Are those 3 attachments enough to clear them, like lifting up with FEL and finish up with RC and box blade?
> If that's not adequate, what other attachment should I buy and how do I use it to clear those sage burshes? Something that is not too expensive...
> What kind of equipment damage (mainly tractor related) might occur while removing thick sage brush, and how should I prevent them?
Thanks in advance.
   / What to use to remove Sage Brushes??? #2
I would strongly suggest that you get a brush guard to protect the nose and radiator.
   / What to use to remove Sage Brushes??? #3
Uncle in Idaho used a 100-HP tractor and something he called a "brush beater" to clear quite a bit of sagebrush. Don't know if this is a regional term for "brush hog" or another type of cutter I'm not familar with.
I think I read an article about Idaho having lots of sage brush which is also quite common on CA's high elevation/high desert (3000'+) area. I don't think my (future) 30-hp tractor w/ brush cutter could do what your uncle did with his 100-hp tractor...
How is everyone else clearing sage burshes?
   / What to use to remove Sage Brushes??? #5
Chazzy, Before I got my CT225 I had a 42" rough cut rotory mower that I pulled with a quad....It worked great on the sage on my property. Anything I could get the quad to drive through or over it would cut. Some of the dry sage had 2-3" stems and the rotory cut it fine if you went real slow. I would think you can get by with what you have (loader, scraper, rotory mower) just fine. Once its cleared a trim every six months or so keeps it in check.
Edit...I did use a battery powered sawsall on a few of the larger green ones!
Have Fun!
Mark
   / What to use to remove Sage Brushes??? #6
Add a tooth bar to the loader pakage it will get ha hold of the brush better for ripping it out I use mine for the mountain laurel i have to clear.
It will help with 1000 other jobs too.
tom
   / What to use to remove Sage Brushes??? #7
Questions are:
Thanks in advance.
It'll work.
Keep your FEL as low as possible so it will lay down the brush. That way, it won't destroy your radiator, fans, belts, and hoses.
   / What to use to remove Sage Brushes??? #8
I use a "Rock Bucket" to remove that type of shrub, root and all. Cutting them off just alllows them to grow back alll the thicker.
Andy
   / What to use to remove Sage Brushes??? #9
I'm set up with a lot smaller package than you have and have effectively taken out A LOT of sage in my area - slowly. I made a toothbar and use a flail mower. Essentially I keep the bucket/teeth about a foot off the ground to push the sage over and curl/push the brush at the base to pull most of it from the root structure and get it to stay laying down. Sometimes I need to backdrag with the loader real quick to squash it flat enough. Then I make a couple slow passes with the flail and woalla.. I have sage mulch instead. Clearing tall sage is kind of a point and attack - you need to attack straight on and at the center of the bush to avoid as many scratches on your paint as possible, but it's almost inevitable. A rotary cutter will do well, but remember that sage is dry and brittle and when snapped it tends to form a sharp point - you may want to screen yourself behind your seat if you don't have a cab and keep everyone away.
   / What to use to remove Sage Brushes??? #10
Use the box blade and back over the plants. Use FEL for any clean up. Radiator will be uninvolved... but a guard up front to protect the radiator is a good idea in general.
It will be even more effective if you have a box blade with two (count 'em, TWO) cutting blades, one facing forward and one back.
The rear facing blade and the tractor in a low range sort of makes up a mini-bull dozer.
Pat
2015 Top Hat T/A 20 ft. Gooseneck Trailer (A50860)
2015 Top Hat T/A...
1999 Allegro Bay Class A Motorhome (A48082)
1999 Allegro Bay...
3-Point Disc Plow (A50860)
3-Point Disc Plow...
Deer Feeder (A50860)
2015 Hooper T/A Trailer w/Mounted Foaming System (A50860)
2015 Hooper T/A...
2007 Toyota Tundra 4WD Pickup Truck (A50860)
2007 Toyota Tundra...
