New CT225, Is the PTO HP weaker than normal
   / New CT225, Is the PTO HP weaker than normal #1
skyline
Member
Near Portland, Oregon
Bobcat CT225, Kubota BX22
Just got my first few hours in on the new machine and I do like it.
However, it doesn't seem very strong with a new 5' Bush Hog 160.
I test drove a 230 and a 5' rankin and thought the same.
I was always a bit concerned with the 19.5 hp spec on the PTO, seemed like a bigger drop (27%) than normal especially compared to others i.e. (botas-27.5 hp gross & 24 hp on PTO). The salesman said some mumbo about tests not being the same. I would have bought the 235 if I could have but just too much extra, they were really pushing the 225.
I see other guys posting here are pulling a 7' brush hog with the CT225. I can't imagine. Is there any truth to the PTO getting stronger after a break in period?
Thanks for any comments.
   / New CT225, Is the PTO HP weaker than normal #2
I run a RZ160 with my CT225 with no problems...on steep hills I have to run it in low range to avoid bogging. I don't have any wet heavy grass to mow but I use it on 2' high brush all the time. Set the mower up so its level or lower in the front for less mulching. The tractor engine will gain a little power as it breaks in and that will effect PTO HP.
   / New CT225, Is the PTO HP weaker than normal #3
These new tractors just don't do the work of their older counterparts. I took delivery of a CT445 a week ago. My 40 hp IH utility will out work it but I sold that. I am glad I still have a Farmall M for heavy work. My biggest concern buying a new hydrostatic compact was its ability to work. I am glad I got the 45 hp and probably should have went with the CT450. I think there are alot of folks who own a compact tractor and only use it for light work. I need a workhorse. Will be evaluating the Bobcat over the next few months. I expect that it will fall short to some degree. There is no such thing as too much power in a tractor, motorhome, or the handgun caliber you decide to carry.
   / New CT225, Is the PTO HP weaker than normal #4
   / New CT225, Is the PTO HP weaker than normal #5
Most manufactures of Rotary Cutters specify five (5) PTO horsepower per foot width of Rotary Cutter. A seven (7) foot Rotary Cutter would call for 35 PTO horsepower. Bush Hog recommends a tractor with 25-40 PTO horsepower for a SQ160 Bush Hog Rotary Cutter.
http://www.lansdowne-moody.com/bushhog-mowing.htm
   / New CT225, Is the PTO HP weaker than normal #6
Which Kubota has those specs...?
B2620HST is 26 Engine HP and 19 PTO HP (27% loss).
B2920HST is 29 Engine HP and 21 PTO HP (28% loss).
BX2660HST is 25.5 Engine HP and 19.5 PTO HP (24% loss).
B2630HST is 26 Engine HP and 19.5 PTO HP (25% loss).
Granted these are all HST, gear tractors have more PTO hp on the equivalent tractor but I can't find any specs on Kubota's site for a sub-compact 25hp gear drive tractor. I highly doubt they have a tractor with that little of a loss to the rear PTO but could be wrong...
The Bobcat CT225 is 27 Engine HP and 19.5 PTO HP which is a 27% loss and seems to be right in line with others...
The Kioti equivalent CK27HST is 28 Engine HP and 20.5 PTO HP for a loss of 27% also. The CK27 gear version has 21.7 PTO HP for a loss of 23%, not a huge difference but certainly an extra 1.2HP.
Make sure you are running at full PTO rpms and make sure the air filter is clean, I would also recommend running an additive like Power Service with Cetane booster after you have reached the break-in 50hr mark. The engine will really come alive after 50 and 100 hours, more engine HP means more PTO HP. I also would not be running a mower until after 50 hours since it should not be run at a constant rpm while breaking in. I did loader work and driving around the first 50 hours varying the engine rpms as much as possible.
Is this a gear tractor or HST? If HST, check the fluid level and make sure you use tractor fluid and not straight hydraulic fluid.
   / New CT225, Is the PTO HP weaker than normal #7
The 225 is set up to use a 72" rotary cutter on the site. You would think it would handle a 60" without a ton of fuss. I hope so, because I have a The same set-up as you. My tractor is not in yet. How long did you wait for yours? I am on week 3.
   / New CT225, Is the PTO HP weaker than normal #8
My 440 seems awefully week on power also, kind of embarassing to tell you the truth. Im half sorry I didnt get the 450 now. I like the tractor for the most part but the serious lack of power really stinks.
   / New CT225, Is the PTO HP weaker than normal #9
Tinman is just running his with the emergency brake on......... Just kidding Tinman... I'm not seeing any lack of power from my 440 hooked to a 6 foot brush hog. I'm gonna hook it up to a 6 foot tiller next week. I'll keep you posted on how it does. Wish you all the best!
   / New CT225, Is the PTO HP weaker than normal #10
Ive been using mine in different applications in the past few weeks. I have a stump bucket ive been working with for a landscaper digging small holes, cuz I dont have my hoe yet, and removing some old bushes and such. My 440 will stall from the lack of power all the time when used not even what I would call hard. The dealer will address the problem as soon as my remotes come in.
2001 Chevrolet C6500 Wrecker Tow Truck (A48081)
2001 Chevrolet...
2000 John Deere 2700 (A47164)
2000 John Deere...
2012 Skytrak 8042 Telehandler (A50490)
2012 Skytrak 8042...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
12ft Stainless Steel Livestock Panel (A48837)
12ft Stainless...
2015 International DuraStar 4300 Street Sweeper Truck (A50323)
2015 International...
