takeing out cement sidewalks
   / takeing out cement sidewalks #1
dirt ditch
Does anyone have experience taking out cement sidewalks with a CUT? A friend purchased several lots around his home which need the old sidewalks removed. I have been ripping along the edge with a subsoiler and he has been using his old case 400 with loader to pop them out from the end. This method is progressing rather slowly and there is a lot of sidewalk to take out.
Tried to use this as an excuse to get a backhoe but that was shot down by my better half.:(
   / takeing out cement sidewalks #2
Is there water near by? I'd think about renting a walk behind cement saw to help it break into manageable pieces. If you could rent a jackhammer or backhoe. I'm renting an excavator right now to remove some stumps. I'll be posting some photos later today to ask for help.
Wedge
   / takeing out cement sidewalks #3
The only way I've done it is with a sledge hammer and throw the pieces into the FEL.
   / takeing out cement sidewalks #5
If you had one of these, it would be very easy. Just run it under the cement, lift, and take it away. That is what it was made for.
   / takeing out cement sidewalks #6
Any thing easy usually gets voted down by the better half.
Is there water near by? I'd think about renting a walk behind cement saw to help it break into manageable pieces. If you could rent a jackhammer or backhoe. I'm renting an excavator right now to remove some stumps. I'll be posting some photos later today to ask for help.Wedge
Just use it for walk removal.
Looks like ya found the hard way.
   / takeing out cement sidewalks #7
Rent an electric pavement breaker.
Sidewalks usually break up very easily.
   / takeing out cement sidewalks #8
I've got about 30 feet of that to replace and am planning on using my BH, that was one of the REASONS for a BH.
   / takeing out cement sidewalks #9
A large skidloader.
Some of those old sidewalks can be 6" + thick. The skidloader can also bust up larger pieces to more manageable weights. If theres rebar then add a torch or bolt cutters if thin enough.
All of my attachments sit on used sidewalk pieces along the tree line.
   / takeing out cement sidewalks #10
Working with a buddy of mine, we lifted the sidewalk up a few inches off the ground and the broke it with a sledgehammer. We went back and used the broken pieces to make a bric brac retaining wall. It stacks real well and the wall has a nice rustic look to it.
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2011 Manac...
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
43013 (A51691)
43013 (A51691)
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
Case 480E (A50120)
Case 480E (A50120)
