Help..Quick Disconnect O ring ?
   / Help..Quick Disconnect O ring ? #1
meddac
I was putting on the backhoe on my BX24 and had a leak at one of the fittings and after disconnecting/reconnecting found the problem to be the little Oring down in the female fitting is missing a chunk. Anyone know the size I need for the backhoe...I think it's 1/4 inch and if you can get it at tractor supply or someplace? Also anyone know if you can just get the oring as I'm thinking this is going to happen again someday and it would be way cheaper to buy a rubber ring than the whole fitting. I'm going to have to just get a fitting locally as I need to do some digging but could order the Oring for later use.
Thanks
   / Help..Quick Disconnect O ring ? #2
I just posted the same thing a month ago or so. Nobody knew and the company that makes it would not tell me, but they do sell a seal kit. Their distrubuter did not have them in stick but could order them and I would have to buy $35 dollars worth. The QD is $25 at the Kubota daeler and they don't sell the seal kits.
All taht said, I measured mine with a sel of vernier calipers and found out the part # is M83248/1-015.
I have extras in my garage if you want me to mail you a couple. The local haerdware stores carried one slightly too small and one slighhtly to large. If you can get one that is slightly smaller you can stretch it then hurry up and put it in and push it together and it will work till you get the proper size. That is what I did. But the part # I listed above is the exact fit.
Deano
I sent you a private message...Thanks!
   / Help..Quick Disconnect O ring ? #5
Thanks
I just did a search on Google with the part number listed above and it came up with the exact part number sold on Amazon.com (bag of 5 O-Rings for $0.99).
Here is the Amazon search results text..
Military O-Ring M83248/1-015 (9/16 ID X 11/16 OD X 1/16 W) Viton 75A (Pack of 5)
Here is the link..
Amazon.com: Military O-Ring M83248/1-015 (9/16 ID X 11/16 OD X 1/16 W) Viton 75A (Pack of 5): Industrial & Scientific
   / Help..Quick Disconnect O ring ? #6
exact part? looks like you are in luck!
UNUSED FUTURE MINI EXCAVATOR HYD BREAKER (A51244)
UNUSED FUTURE MINI...
2013 NISSAN JUKE (A50324)
2013 NISSAN JUKE...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
1993 Barrett Gooseneck Livestock Trailer (A50514)
1993 Barrett...
1991 Peterbilt Dump Truck (A50323)
1991 Peterbilt...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50322)
2020 Kubota Z723KH...
