What do you use your Back Hoe for?
   / What do you use your Back Hoe for? #1
Starboard
Dallas, Texas
Never owned one. Never thought I needed one. Yet, a lot of you say they are really important to you. So, what uses do you get from them?
   / What do you use your Back Hoe for? #2
Got my backhoe to use for digging out lots of eucalyptus trees and stumps.
Roy
   / What do you use your Back Hoe for? #3
I use mine for digging up stumps and rocks mainly.
   / What do you use your Back Hoe for? #4
Mostly stumps with a few water pipe ditches thrown in.
   / What do you use your Back Hoe for? #5
Asides from the obvious digging ditches and holes.
With my BH I've
pulled post
removed trees and stumps
cleared brush
Used as a crain for lifting and installing culvert.
Tore out side walks .
Also pushed the joints together when joining pipe and or culvert.
Used as a power rake for dragging out brush and trash that I could not get to otherwise.
The BH is a very handy power rake and mini scraper.
I'd b just plain lost with out a BH.
Rite now as we type there are about 4 assignment waitin on the Back Hoe.
Some pictures of some of the projects I have used the BH for.
   / What do you use your Back Hoe for? #6
The problem with owning a BH is you will do projects that you normally would not, owning a BH creates work. Now that I think about it owning a tractor creates work.
Here is a few for me.
For myself
Dug the footings for an addition on the house
Drainage ditches and keeping them clean and or digging them again
Burying horses and other large animals (boy I hate digging these by hand):D
Dug out a small pond
Dug out a small spring and set 2, 4ft round x 4ft high tiles to make a water holding tank for the barn.
Water lines (4 ft deep)
Septic leach fields
Post holes for my new deck (4 ft deep)
Dig out for Volleyball court
Set electric pole
Dig out for pole barn
Dig out for retaining walls
Dig out corner post holes for fencing
Dig out tree stumps
Dig out large rocks
Moving smaller trees (for the wife):cool:
Electric lines
Rock garden (couple times, the first one is never right):rolleyes:
Finding septic tank lid
Dig out for Hot Tub;)
Setting Hot Tub;)
Dug out for an above ground pool (then gave the pool away and filled it in a few years later)
Backing into things:eek: (don't ask)
For others
Burying horses
Septic leach fields
At least twice a year something or another for a neighbor
Electric Lines
Dig out for foundation wall repairs
   / What do you use your Back Hoe for? #7
Trenches and holes
Placing rocks (with thumb)
Spot repair of driveway -- I have a gravel driveway with a few spots which have persistent potholes. A pothole repair lasts a lot longer, if I dig up the base rock and re-pack it before repairing the pothole.
   / What do you use your Back Hoe for? #9
Just barely got mine, so far pulled a stump and dug for a gate.
I've been mainly using it as an exercise machine by hooking and unhooking it.
   / What do you use your Back Hoe for? #10
Removal of Stumps or whole trees, digging trenches & planting trees is all I have used mine for. I tried the FEL for tree/stump removal, what a job that is.
E-Z Trail 672 Head Cart (A50514)
E-Z Trail 672 Head...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
2012 John Deere 7280R MFWD Tractor (A52128)
2012 John Deere...
New Mahindra 8100 CLGC Euro Loader (A50774)
New Mahindra 8100...
