FEL operation
   / FEL operation #1
BlacknTan
Adirondacks of NY
Kubota B-7800
Does anyone know of a good book or online tutorial to teach the fundamentals of effective front end loader operation?
I'd like to become much more proficient with the operation of the loader for more than just use as an expensive wheel barrow.
   / FEL operation #2
I don't know of any written training, but look at Youtube videos and play with it.
I just extricated a stump. I filled in the hole and now go out an play in the dirt a bit and play with the stump. It's my little sandbox :)
A lot of it seems to be motor skill and getting so you automatically lift an curl when you want to.
   / FEL operation #3
My first noticable improvement was when I added a toothbar. Makes it an entire different tool.
Then I attribute the rest to time on the stick and a patient imagination of the ways a loader can be helpful (including additional quick attach implements). Still learning after several years of patience.
   / FEL operation #4
An old Ford loader operator's manual (or maybe even a newer manual) - it would provide the basics of operation which would be a good foundation on which to build with experience.
   / FEL operation #5
Have you looked in your loader owners manual? I think that some of them have basic instructions on how to do different procedures. My 3215 loader manual has like a comic book section in it that shows how to go about back filling, loading the bucket in a dirt pile etc. Actually would be very helpful for a first timer.
   / FEL operation #6
In my opinion, using a FEL is like riding a bike. All the books in the world cannot teach you how to use it. It's something you have to learn for yourself. The way you operate a dirt bucket is different from a rock bucket. A grapple is much different from forks or a bale spear. The way you operate a 25 hp compact is different from the way you use a 65 hp utility tractor. 2wd tractors have slightly different feel and technique to 4wd tractors. I think your best option is to learn the feel of your FEL through practice and then get tips for doing specific jobs from experts. That expert advice can be found here on TBN.
When I bought my tractor and loader, I got an operator's manual for the loader. It had several good tips for loader use. Do you have an operator's manual? I'd bet that might help with many techniques of doing common loader jobs. I have 1500 hours on my tractor and I'm still finding new ways to use my loader.:)
EDIT: It's amazing how many of us posted the same info in the last few minutes.
   / FEL operation #7
Get yourself a load of sand or gravel and have at it. After a few hours, you'll get the hang of it. No substitute for seat time. Just be sure you do your practicing with all four wheels on dirt or grass, not on concrete.
   / FEL operation #8
It doesn't matter how big the machine, the key to good loader work is finesse and time behind the wheel. They look like a brute force tool but they are not. Find a spot where it won't matter if you tear things up a bit and practice scraping up soil and putting it into a pile. You will have better luck taking small bites and scraping over a distance rather than digging a hunk out of the ground. If (I mean when!) you do dig a hunk out, back up and refill the spot before continuing. To start, place the bucket flat onto the ground, tip it down a couple of degrees, begin moving forward. As soon as you feel the bucket cut into the ground, level the bucket out while continuing forward. If done correctly, you should have a small drop onto a flat piece of dirt. If you find your tires spinning too much or the tractor stops moving forward, then you should take thinner cuts.
Once you have a nice pile, put the dirt back and smooth it out with the loader. This will give you some practice using both downforce, bucket angle, and the float position.
If you don't have a spot that you can dig, then buy a load of soil. Practice spreading it out then picking it back up. With a little practice, you will be able to pick the dirt up off of grass without tearing up the grass (much!)
   / FEL operation #9
Also make sure your tail is heavier than your head!
Get a nice heavy load on the back. I'd suggest a backhoe, but weighted tires, a box blade or 5 or 10 bags of concrete would do.
   / FEL operation #10
That technique may work well in Florida dirt. Not so sure here with the hard clay :( I have a contractor here with a 10 ton bulldozer (Case 860 with 10' blade) and he commented that the blade was just sliding over the surface, wouldn't dig in unless he used the corner of the blade. And the dirt isn't even dried out yet!
Bottom line, I suspect that the techniques required (and sometimes the equipment required) depends very much on the local soil conditions.
Ken
2015 Ford Escape SE SUV (A55853)
2015 Ford Escape...
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
John Deere 2355 (A53317)
John Deere 2355...
2016 Dodge Journey SUV (A53424)
2016 Dodge Journey...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
Hose Reel (A53424)
Hose Reel (A53424)
