NH rake tines?
   / NH rake tines? #1
disco
Minnesota, Goodhue County
JD 4310 & JD 4020
Hi,
I have a NH 256 rake. I'm getting tired of replacing the rubber mounted tines. Does anyone know if I can change them over to the all steel ones?
Thanks Paul
   / NH rake tines? #2
Should be no problem you will just need the support holder NH part # 792493
And the steel tine part # 64562 Your nut and bolt that you have should be fine.
   / NH rake tines? #3
Hi,
Thanks Paul
Why are you losing so many?
   / NH rake tines?
It's an older rake. They are pretty worn. (like that when I bought it.) The rake works fine. The tines are all different lengths due to wear. The rubber mounts are dry rotted. Maybe it just needs all new tines?
Thanks Paul
   / NH rake tines? #6
Thanks Paul
Probably, we run 3 of those and only lose a 1 or 2 a year and replace a few more than that.
   / NH rake tines?
Well I raked about 16 acres of Alfalfa this afternoon. Lost 1 tine. Had a guy stop buy and bought 150 bales of grass hay. Gonna buy new tines. YES!!!!!!!!!!!!
Paul
   / NH rake tines? #9
If I recall the steel tines with the holders are actually cheaper then the rubber mounted tines. I am in the process of replacing my rubber tines to steel on my 256 as the rubber ones break. I like the steel tines a lot better.
   / NH rake tines?
Well alot has happened since I posted this thread,
I bought my rake from a church group that claimed the gear box had been totaly rebuilt. WRONG. Of course I found this out with 19 acres of alfalfa on the ground. Did'nt have much choice but to bring it in to a NH dealer. They let me borrow a 10 wheel rake. I liked the speed. Liked the 256 better. They saved me. Anyway had the rake totaly rebuilt. Put new tines on it when I got it back. Works GREAT now.
Thanks for all the help on buying equipment! Baled 470 bales today. Another 4-500 tomorrow.
Thanks again,
Paul
2006 Ford E-350 Passenger Van (A51692)
2006 Ford E-350...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
2014 Chevrolet Tahoe SUV (A51694)
2014 Chevrolet...
Curry Bac Bottle, 4700 gal bottle with pump/vac  (A52384)
Curry Bac Bottle...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53473)
2017 KINZE...
