Box Scraper box blade repair parts
   / box blade repair parts #1
easeup
TEXAS
I have bent the box blade pieces that connect the A frame to the lift pins. this is proabably the third time I have done it and I do not wish to heat and bend them straight again. In the attached pic of a similar unit I copied off this site, these parts are colored black on the LH side.
does anyone know where I can get these replacements. My box is an Independence Manuf. out of KS from 40 yrs ago. but I believe other brand would probably fit. any help?
   / box blade repair parts #2
Are you talking about the pieces of flat steel that connect the center link to the lower hitch pins? The one that has two opposing bends at each end, and a hole?
Any metal fab shops in your area? I'd be looking into getting something that doesn't bend. Either larger bar stock or welding some additional support on them.
   / box blade repair parts #3
You might be able to find something here.
Agri Supply
   / box blade repair parts #4
Could try the King Kutter website. Under PDF Manual Library choose Parts manual and download. That manual has part numbers for all there equipment including box blades. Looks like you can order parts online or call them.
King Kutter Incorporated
you are correct; and I agree that is a suitable option. I will go with that if I do not find a replacement part. these pieces are 3/8 thick or more and even though they can be straightened and beefed up, it is not that easy to get them to the same size so that the blade sits square & level when done. thanks
   / box blade repair parts #6
There is no part for that. It looks like you ripped the square tube. Just bent it back and weld some more support pieces, like 1/2 by 2 in on front top, and bottom rear. Do this for all if you have the material.
How about a top side picture.
   / box blade repair parts #7
Maybe, I'm confused, but it appears the draft link pins attach to the orange bar and that that bar would set the alignment / levelness of the BB. If the black bar going to the center link were off, it seems it would just shift the centerlink to one side or the other.
I'm sure I'm over analyzing something, hopefully you can find a suitable replacement. It would probably be cheaper than getting one made.
   / box blade repair parts #8
It looks like he either hit something and the shanks broke the holding link at the top, and there was enough slop to force it at that angle, or as I said before, it bent or busted out the metal at the top and bottom, any of which can be fixed.
   / box blade repair parts #9
40ys old? I'd MAKE new parts.. and beef them up.. or repair the old ones again AND beef them up.
heat, beat, torch, welder, + scrap iron= good piece of farm equipment!
soundguy
40FT Shipping Container (Modified for Parts Storage) (A51573)
40FT Shipping...
HARDEE D-3-816 LOT NUMBER 155 (A53084)
HARDEE D-3-816 LOT...
2004 Honda Odyssey Van, VIN # 5FNRL189X4B025339 (A51572)
2004 Honda Odyssey...
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
