Kubota M4800- help on rear hyd. install
   / Kubota M4800- help on rear hyd. install #1
jayste
"Sold the 1/4 of a 1/4 but still tractorin' "
2004 Kubota M4800 SU
I have a 2004 M4800 S/U Kubota and want to install rear hydraulics on it. As it stands all I have is the 3PH, no draft and no FEL. Where do I start?:confused:
Any info would be appreciated. Thanks.
Jay
   / Kubota M4800- help on rear hyd. install #2
Have you tried your dealer?
   / Kubota M4800- help on rear hyd. install #4
Jay,
The SU (special utility) was built as a price fighter so it did not have the casting to mount the auxiliary valves.
There is a kidney shaped cover on the side of the transmission that has several drilled and tapped holes behind it - one has to be plugged with a specail plug available from your Kubota dealer. (There is a service bulletin on this)
Of the remaining two ports, one will supply fluid under pressure from the hitch pump and one is the return port. You can now supply an open center valve for auxiliary, loader, log splitter - whatever you need hydraulically.
Again, like Kenny says - go to the dealer and get the special plug part number from the service bulletin and you will be in business.
Good luck!
Yankee Clipper, thanks for the insight. I guess a trip to the local dealer is in store. I kind of thought this tractor was that way. I bought it from my F-I-L who bought it new. He never had need for rear remote but I'd like to have it for future implements. Thanks again.
Jay
2018 Autocar ACX Xpeditor Garbage Truck (A55852)
2018 Autocar ACX...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A57024)
Greenworks...
2008 INTERNATIONAL PAYSTAR 5600I DAYCAB (A55745)
2008 INTERNATIONAL...
2019 CUMMINS CM20-1 PORTABLE SKID GENERATOR (A55745)
2019 CUMMINS...
MCELROY COOL PACK 20 (A55745)
MCELROY COOL PACK...
