Hooking up my bushhog
   / Hooking up my bushhog #1
R_Walter
Gold Member
Lindrith, NM
Kubota L4240
Another of those messages on hooking up an attachment.
In hooking up and adjusting my bushhog, should it be resting with pretty much half the weight on the single tail wheel or should more than half of the weight be on the 3PH? Or, should almost all the weight be on the 3PH and the tail wheel is only used to keep the back of the bushhog from dropping down too far as the tractor goes up and down over depressions and rises?
What's the proper balance? Thanks.
   / Hooking up my bushhog #2
I personally don't think it matters that much. The downside of having too much weight on the rear wheel is that it might dig in in soft ground while if you have too much weight on the 3PT then the tractor's steering might be a tad touchy but basically the thing should work fine whether you have it mostly on one or the other.
   / Hooking up my bushhog #3
I would think most of the weight should be supported by the tractor. If you consider the poor bearings and small size of most tail wheel assemblies they will not last long with high loads on them. Better to consider it a guage wheel of sorts.
Steve
   / Hooking up my bushhog #4
Most bush hogs have a mechanism where the top link connects that allows the top link to articulate. Properly adjusted, the bush hog should be supported by the lift arms and the tail wheel, there should be no tension on the top link. Adjusted this way, the weight distribution will take care of itself. I'd guess that roughly half the weight is on the lift arms and half on the tail wheel, but that doesn't really matter.
   / Hooking up my bushhog #5
I think that is the best answer.
   / Hooking up my bushhog #6
I agree with GaryCrowell. Another issue with little weight on the tail wheel is that it chatters and is less likely to roll and swivel when it's supposed to.
   / Hooking up my bushhog #7
I learned the hard way to keep the top link chain loose. I have very hilly and uneven pastures and, if the chain goes tight over a bump, the tail wheel will rotate around backwards or sideways, then slam down onto the ground as I head through the following dip. I first bent the wheel support arms sideways and then actually tore the metal at the top of the fork at the base of the tail assembly verticle axle.
Now I am careful to back off the toplink tension a long ways so the tail wheel stays on the ground. This means that I can't pick the mower all the way up with the 3ph without first getting off the tractor and tightening the top link a bit, but it is worth the bother of an extra dismount not to have to weld up or pound straight the tailwheel forks again.
BOB
   / Hooking up my bushhog #8
The weight should be equally divided.
If there's too much weight on the 3PH, the tail wheel will bounce, and the mower won't follow the contours of the ground smoothly. It will also stress your 3PH more when you hit bumps and dips.
I don't think it's possible to have too much weight on the tailwheel. If that occurs, then your mower adjustment will be wrong.
Always make sure your top link has a good bit of slack when your mower is set to the mowing height you want. When you raise the deck with the 3 point, the deck should still be fairly level or drooping just as the tailwheel comes off the ground.
   / Hooking up my bushhog #10
As others have said, the weight distribution will take care of itself when it is properly set up ...i.e., with a swinging link or chain at the "toplink" that allows the tail to kick up or drop down sufficient for the undulations in your field, with some to spare. Indeed, it is not unheard of to disconnect the toplink except for transport.
That taken care of, the amount above the ground at the front of the mower will be the height of cut, and the rear should be higher to allow easy discharge (which may mean you have to adjust the tail wheel) ...how much higher may depend on how high the stuff is you are cutting and how quickly it would build up underneath.
The next caution is that with the rear "properly" raised, there is cosiderable danger to anyone/thing behind the tractor (for a fair distance) when you are mowing ...hopefully, you have "chains" dangling as a guard ...which will slow down (but not necessarily stop) potentially lethal projectiles.
197390 (A50459)
197390 (A50459)
2024 John Deere 872GP Articulated Motor Grader (A49461)
2024 John Deere...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A51222)
2018 FREIGHTLINER...
NANCE UNDERGROUND CONDUIT BOX (A50854)
NANCE UNDERGROUND...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
1999 FREIGHTLINER FL80 (A50854)
1999 FREIGHTLINER...
