Oil & Fuel 3054 spitting oil from valve cover tube.
   / 3054 spitting oil from valve cover tube. #1
1hitechredneck
I have a 96 Kioti 3054 that spits oil from the tube that comes off the valve cover area. Have to add oil (40W) about once every 1 1/2 hours of use. I was told it was "blow-by". Everything else seems to work great (PTO, FEL, etc). Has approx 450 hours on it. Sure could use some suggestions. Other than that, I love the tractor.....
Thanks
Norm
   / 3054 spitting oil from valve cover tube. #2
Thanks
Norm
Yep, certainly sounds like "blow-by" which can only be caused by faulty rings and/or cylinder walls. It sounds like you're not the original owner, in which case, did you get it from a dealer or private sale? If a dealer, and you haven't owned it too long, I'd check with them;if a private sale, I'd guess your SOOL. The only cure is an extensive and expensive re-build :(
Thanks very much for your reply. You're correct, I'm not the original owner. Bought the tractor last month for $4K with an FEL. From what you're saying, this fix could cost a bundle. Would it be worth the investment? I also bought a trailer and a new 5' bush hog after I bought the tractor. There is a local dealer about 5 miles away.
Norm
   / 3054 spitting oil from valve cover tube. #4
With the low hours on the tractor, you may be looking at simply a bad or broken ring. That isn't too big of a job to do yourself (afternoon in the barn). You will know if the cylinders are bad when you pull the head, but I would expect a bad ring set in one of the cyclinders. It only takes 1 to cause the excessive blow-by.
Take care of it now. You'll be better off.
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A53472)
Greenworks...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A53472)
2-Row Peanut...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2021 CATERPILLAR D4 LGP CRAWLER DOZER (A51246)
2021 CATERPILLAR...
2014 John Deere 5060E Tractor (A51573)
2014 John Deere...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A52748)
2000 Kenworth W900...
