Gambrel Roof Barn - metal sheet fix
   / Gambrel Roof Barn - metal sheet fix #1
Dave5264
Gold Member
Near North Ontario Canada
08 Montana C5264, 2011 McCormick CX100 XS
Hi folks, Ive got a large bank barn with a Gambrel Roof, as usual its metal, i have 2 missing sheets that came off last month in a wind storm.
picture #2 in this post shows the heigt & size of the Barn - damage is on the upper section
http://www.tractorbynet.com/forums/montana/145004-pic-new-5264c.html
no luck getting any local person to come and do it
its really high up, and my wife as forbidden me from going up
im not sure if Im game to give it a go or not, Id for sure need a harness and safety lines before id ever venture up there....any of you folks done this ? and how?
getting up and screwing them down is one thing, manouvering up there with sheets of metal is another
   / Gambrel Roof Barn - metal sheet fix #2
Piece of cake.
Done it many times.
   / Gambrel Roof Barn - metal sheet fix #3
When I was young and dumb, all the time. Rope, harness and a friend. Good Tennis shoes, stickier the better, or if it was cloudy and cool I found better traction with bare feet. If it is just two of you, walkie talkies a must, but you probably want to have a group of friends, if for nothing else when it goes south it is a great group story.
If you have to be alone, maybe you want to have a snorkel delivered...
Snorkel - Choose your location
   / Gambrel Roof Barn - metal sheet fix #4
I'd second the snorkel/genie/boom lift idea. If there's *NO* wind, you could strap the metal to the cage and ride up their with it. If there is even the slightest breeze, I would pull the sheet up with a rope after you're in position. That is a lot of surface area and makes a great sail :)
I've uses a 55' genie to take OSB sheathing up to the second story of a house. Just make sure it's driving on solid ground. They get stuck in mud fairly easily.
-rus-
Snorkel is a good idea, ill look into that
   / Gambrel Roof Barn - metal sheet fix #6
I watched bridge re-construction where they had ones that extended to 85' pointing almost straight up. The ariel platforms are really a good way to go...
   / Gambrel Roof Barn - metal sheet fix #7
Rent a lift if you can and are afraid of unshore footing
or
Rig up a chicken ladder so you can stand on it done it many times even in a immobilizer after knee surgery with my 10 year old son helping me.
my wife read me the riot / idiot act but I would probably do it again.
tom
or
tom
Chicken ladder? is that one of those that lays against the roof, hooks over the ridge etc.?
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A52141)
2020 FREIGHTLINER...
2018 Atlas Copco Pas200HF Diesel Dewatering Pump (A52377)
2018 Atlas Copco...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
2017 Takeuchi TL8 (A47477)
2017 Takeuchi TL8...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
2019 KENWORTH T880 DAY CAB ROAD TRACTOR (A51406)
2019 KENWORTH T880...
