Need new/used ??for cutting on road front
   / Need new/used ??for cutting on road front
dodge man,
No that won't work --your right too dangerous plus I'll get stuck heavy water area at times.
tommu56,
Thanks I'll check that out.
I did get a reply from the other company:
Dear John,
The machines are made by our manufacturer in Italy and their website
is;
GL1 - European technology
Hopefully they can help you with your queries, but if you do need any
more information from us then please let us know.
Best regards
Janet Welburn
Tel: 01944 768232
   / Need new/used ??for cutting on road front #12
Wouldn't ZTR do the job? We have Grasshopper 725 and mow 200 yards of a ditch with 3 ft tall almost perpendicular side. You just push the deck up and them back off. Ditch like your will be a piece of cake for a front mounted ZTR.
I wouldn't be able to approach it that way.
   / Need new/used ??for cutting on road front #14
Hello Johnny dont know what dealer you have in your area but most carry what is call a 3pt lift boom mower. New its a little pricey for your house but check ebay and craigslist for a used one they are alot cheaper..good luck
That's exactly what I need---- your Tractor.
Nice pictures cool ride.
True Dealer support is important.
I'll check craiglist maybe I'll get lucky.
   / Need new/used ??for cutting on road front #16
I agree with Woodland, straddle the ditch and run down the center. I have done that in the past, if that is not practical, I would consider killing the grass and putting in rock.
   / Need new/used ??for cutting on road front #17
Then it will be a real bear to mow after the weeds grow up through the rocks.
Rocks is the worst thing he could do/
Looking at your pics you would just ride on one side of your ditch. Them make U turn and mow the other side. Done. 3 minutes job.
The Tractor does not fit in the ditch and if I attempt it it will not come out or worse flip over.
   / Need new/used ??for cutting on road front #20
Zero turn mover, (I have specific experience with Grasshopper) will not flip over even on 45 deg slope even if you try.
STORAGE FEES (A53426)
2004 Hydraulic Breaker Excavator Attachment (A52377)
2004 Hydraulic...
UNUSED GREAT BEAR 78" HEAVY GRASS FORK GRAPPLE (A51248)
UNUSED GREAT BEAR...
2010 JOHN DEERE 4730 LOT IDENTIFIER 239 (A53084)
2010 JOHN DEERE...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A53472)
2012 UNVERFERTH...
ECHO PB-580 H/T GAS BACKPACK BLOWER (A51248)
ECHO PB-580 H/T...
