Need advise on a disc cutter 3 point for hay.
   / Need advise on a disc cutter 3 point for hay. #1
cmharcou
Member
I am looking to purchase a 3 point disc mower to cut hay. I have a kubota l4400 with 44hp. I am interested in a 6 to 7 foot model. Any suggestions from experience on this board. I have checked on kuhn, massey and vermeer but all are in the $8k range. Any other comparables that are a little less? Thanks for any advice.
   / Need advise on a disc cutter 3 point for hay. #2
I'm waiting right along with you. I have a comparable HP tractor and was wondering the same thing. This post got to the 2nd page so I'll bring up the list for us.:D
Jay
   / Need advise on a disc cutter 3 point for hay. #3
You're a bit light on horsepower, you might consider a sickle bar mower. Alternatively, I believe Carter & Carter (search for CCI on this board) sells a drum mower that only needs 20hp.
   / Need advise on a disc cutter 3 point for hay. #4
Take a look at the CCM drum and disc mowers.
   / Need advise on a disc cutter 3 point for hay. #5
The 3pt disk mowers are very heavy; my neighbor has one (8 - 9'?) on his 50hp kubota and he says that it is hard on the tractor. He is in the process of replacing it with a wider cut but tow type disk mower.
2015 Ford F-350 4x4 Ext. Cab Liberator 3,200LB Crane Mechanics Truck (A52377)
2015 Ford F-350...
GEHL RB1470 TOTAL DENSITY CONTROL HAY BALER (A51247)
GEHL RB1470 TOTAL...
UNUSED CFG NT18K EXCAVATOR (A51247)
UNUSED CFG NT18K...
2013 New Holland T4.75 Tractor (A52384)
2013 New Holland...
1266 (A50490)
1266 (A50490)
