Diamondpilot
Super Star Member
- Joined
- Jan 18, 2007
- Messages
- 16,331
- Location
- Daleville, IN
- Tractor
- Jinma 254/284 Ford 861 Powermaster at work
And I've owned 13 Ford trucks in a similar time period and never had an "axle problem", either, but that's not the issue. The issue is the limited slip for the most part don't work. How many trucks a person owns makes no difference.I'd trust a mechanic that works of Ford rears and drives a hyundai more than someone who owns a bunch of Ford trucks. All the Ford l/s rears that we've opened up on them in the past had clutch packs that were worn to the point that they didn't engage properly or would let go after engaging briefly well before 100K miles. Plus the hassle of adding friction modifiers to get them to work at the little that they do work.
If you knew how a Ford "limited slip" rear worked, you'd know that it relies on clutch packs to engage that only work in light off roading conditions. I replaced the limited slip rear in my last (2) Superduty 4x4's with Detroit soft lockers which greatly improved the performance of the rear axles in muddy spots. You'll see most serious Ford off roaders will do the same. My limited slips did little in test after test except lock occassionally on wet snow or grass only to let go again before getting unstuck. They are better than nothing, but not designed for much more than light off-roading.
Limited slip rears versus locking rears:
YouTube - Silverado vs. Tundra Twist Ditch
YouTube - Eaton Locking Differential Demonstration
YouTube - Difference btw. Locker and Limited Slip
Ford limited slip rebuild
Fun stuff:
YouTube - Dodge... limited slip
YouTube - Chevy vrs Ford 4x4
YouTube - SILVERADO VS A FORD F150
I will probably get in trouble for saying this but you spread so much crap and tell so many lies you are now starting to believe yourself. For example, that first video is such BS. The Eaton locker on Government Motor trucks is about the most rudimentary basic locker on the market. The Tundra come from the factory with a Full Electronic Locker, not some G80 that is automatic and disengages at around 25mph of wheel spin. The video was clearly biased and was not using a Locker Equipped Tundra. Trust me I have drive both and owned a G80 equipped Dura Junk and my Detroit Electronic Locker equipped Titan and there is no comparison. The Eaton G80 is better than nothing but does not compare at all with the electronic lockers that Ford, Nissan, and Toyota use. Dodge is the only manufacture that does not offer a locker, at least the last time I test drove one around December. Granted Ford does not offer a Locker in its SuperDuty line and should get on the ball.
You can quote all day long from brand specific info and it will always sway the way you want. I swear, you must crazy if you really believe 1/10th of the stuff you post Duke!
Funny thing is about 75% of the tow trucks, police cars, taxi cabs, and ambulances on the road are Fords. I really can not see how they keep them going with the rear ends dropping out, engines leaking at every seam, spark plugs flying left and right, ect, ect, ect. Do you see how foolish you look?
Sorry everyone for getting off topic but Duke (aka Builder) is miss leading. I am Ford Loyal when it comes to 3/4 and 1 ton Trucks. That is as far as it goes. My other vehicles are a Nissan and a GM. They were what was best for me and my Family. My extended family drives GM, Honda, Ford, Toyota, ect. We educate ourselves and buy what is right, not what some expert know it all one ups man like this guy tells us all about.
Chris
