Finishing Mower
   / Finishing Mower #1
CanJim
Toronto
WFE 37
I'm thinking of buying s used finishing mower, probably 72". What are the advantages of rear versus side discharge. I'm leaning towards rear because I don't want a line of grass but as I don't have much experience I'd appreciate some opinions. I currently use a Mott flail mower but it's getting a bit old, and I supplement this with a Bush Hog which does a good job but isn't a finishing mower by any stretch of the imagination.
Any advice on what to look for and/or avoid would be great.
   / Finishing Mower #2
I think the rear discharge is the way to go. It doesn't wind row, and you can get right up close to what you are mowing from either side. I have a 72" Landpride that does a fantastic job.
   / Finishing Mower #3
My Woods PRD7200 is a rear discharge model and so far I've been very happy with it. CT230 is correct in the fact that the rear discharge models won't windrow, or at least won't as bad as the side discharge models. As long as your not cutting super wet grass, that is really tall, than you shouldn't have a problem. That's the only time I have run into that. Just keep up regularly with your mowing, or mow when the grass is completely dry, and you'll be fine.
   / Finishing Mower #4
I think if you keep the grass in check the rear mower would serve you well. It actually gives a nice ground-following cut on land that has small hills because the wheel base (if we can talk about that on mowers) is about the same as riding mowers. The towns here uses woods rear mowers and the parks look good.
   / Finishing Mower #5
Woods Rd6000...just don't let the grass get out of hand and this is a wonderful mower.
   / Finishing Mower #6
I have a Bush Hog RDTH 60 rear discharge finish mower and disagree with the wind row statements. The rear safety chains rake the clippings up into clumps as you mow and leave grass piles everywhere.
   / Finishing Mower #7
I have a Bush Hog RDTH-72 rear finish mower. It has the rear chains and mulching blades. I have no problems with the clippings at all. I like the way it cut and not had any problems with it.
Wally
   / Finishing Mower #8
Backing up slopes you'll get more w/rear,also less chance of getting belly hung mowing wet area.
   / Finishing Mower #9
I have a 72" Landpride. It doesn't have the chains off the back, so it lays the clippings out fairly evenly acrosss. I'm not sure that the chains add much advantage if you are mowing a yard, where I would assume there isn't a lot of surprises. I can see the advantage to having them on a rotary cutter.
   / Finishing Mower #10
I've used the Bush Hog RDTH-72 - it has a nice rugged cutting deck but the castor wheels are small and don't have much offset from their pivot - so they can dig in and plow when changing direction or turning in tight places.
I keep going back to the Woods RM990. With large free-pivoting castors and swing-back blades, it's a very effective machine, built to last a long time. One thing - it needs more power than the brochure claims. It's happiest with 32-35 pto hp if the grass is dense or damp.
2015 Ford F-450 Cab and Chassis Truck (A51692)
2015 Ford F-450...
2025 JMR 44in Bucket Skid Steer Attachment (A51691)
2025 JMR 44in...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
2006 iDrive...
2017 Isuzu NRR 22ft Box Truck (A51692)
2017 Isuzu NRR...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
