slip clutch
   / slip clutch #1
Deerlope
Northern, New York
Kubota L3830 03: RTV 900
I have a Bush Hog SQ172 and when I bought it the dealer recommend against getting a slip clutch model. He said there could be problems with ths disk after it sits for a few months. Now I want to add a clutch after shearing 8 pins in the last 2 days. Has anyone ever done this? Does it require any machine work or welding?
   / slip clutch #2
Harbor Freight has one for $60 that should just slip on over a six spline shaft and the standard 6 spline yoke would go over that. The PTO drive line might have to be shortened after the clutch was added, maybe. Agri-Supply sells different shaft styles slip clutches, but, are a little more money. bjr
   / slip clutch #3
Deerlope, I'd certainly be leary of that dealers advise in the future. He may know sales but he doesn't know equipment.
I use a tractor mount slip clutch & highly recommend it's use. If you haven't already done so, search for clutch adjustments, it's been well posted. MikeD74T
   / slip clutch #4
If slip clutches were the only way, there wouldn’t be mowers made without them. Fact is, shear bolts have their place. And a mower that is going to sit for long periods of time is a good example, just like the dealer suggested. I have to question what is happening that caused you to shear 8 pins in two days. Either you have a lot of hidden objects in the weeds, or your bolts are too soft.
   / slip clutch #5
I agree.. a slip clutch is an UPGRADE to a shear bolt.
a properly maintained SC is a nice piece of work.
soundguy
   / slip clutch #6
Yep, I wouldn't have a rotary cutter without one. Do they require maintenance? Sure. Every few months? No. Maybe once or twice a year. Takes about 15 minutes at the most.
   / slip clutch
If slip clutches were the only way, there wouldn稚 be mowers made without them. Fact is, shear bolts have their place. And a mower that is going to sit for long periods of time is a good example, just like the dealer suggested. I have to question what is happening that caused you to shear 8 pins in two days. Either you have a lot of hidden objects in the weeds, or your bolts are too soft.
When I back into a bush of honey suckle beleive me there is a lot of hidden rocks in there. Then there is that area where I thought I would remember where I cut the trees very close to the ground.
   / slip clutch #8
sounds like the place for a slip clutch!
soundguy
   / slip clutch #9
I agree, it certain sounds like you should have a slip clutch. Again, in your dealers defense, a slip clutch isn't the perfect choice for some owners and/or situations. He was wrong this time, but one mistake doesn't automatically make someone an idiot, as was suggested.
   / slip clutch #10
I had the same issue. I bought a Woods 60 inch BrushBull Extreme, and it was shear pinned. Six bolts one day made me start to look around. The dealer wanted $235 for a woods shaft replacement including a slip clutch. Instead I bought the slip clutch add-on from Agri supply. It bolts (with grade eight) to the gearbox input shaft, and accepts the Woods stock pto shaft input, with another gd 8 bolt. No more shearing and I use it very hard at times, in the dirt. It slips and then comes right back up to speed.
Here's the one I bought, and it fit perfectly...
SLIP CLUTCH W/1 3/8SMF M X1 3/8SMOOTH FE - Agri Supply
They have other configurations of it, in case you dont have a 1 3/8 smooth input shaft on your gearbox.
2008 HONDA GOLDWING GL1800 TOURING MOTORCYCLE (A50505)
2008 HONDA...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A49461)
2012 Vermeer...
Bus (A50323)
Bus (A50323)
2019 Fontaine Traverse HT T/A 48ft. 41 Ton Lowboy Trailer (A49461)
2019 Fontaine...
2019 KENWORTH T880 (A50854)
2019 KENWORTH T880...
2019 VOLVO VHD84F300 TRI-AXLE DUMP TRUCK (A51222)
2019 VOLVO...
