Anyone know MF autotronic transmissions
   / Anyone know MF autotronic transmissions #1
Builder
Super Member
East PA or 750 mi. east of a short man named Dar__
Kubota, AGCO, New Holland LB
Trying to learn more about the autotronics in the late 80's MF 30XX series tractors.
Anyone know what they're all about, reliability, durability, parts availability etc.?
   / Anyone know MF autotronic transmissions #2
Autotronic is the name given to the system that automates some transmission functions, it comprises a control module under the cab RH floor and several sensors in the transmission and hydraulic system.
Autotronic disengages 4wd at around 10mph to prevent transmission wind up and excess front tyre wear, it also controls the differential lock engagement(I cant remember exactly how) It engages the 4wd to provide 4 wheel braking when the brake pedal is depressed. It monitors pto engagement and shuts off the pto if a sudden excessive shock load is encountered. It provides a facility to engage the diff lock when the linkage is lowered (useful when ploughing) and disengages it when the implement is raised out of work automaticly.
It also monitors and controls transmission range change, transmission oil pressure .. It is a fairly reliable system and usually operates quitely in the backround until a problem occurs and problems are often due to low voltage to the control module, poor earthing, loose/damaged wires and connections. Damaged and brittle wires are common on the 30xx tractors now, many being around 20 years old now
Parts , sensors are available but can be expensive . AFAIK the original type control module are no longer available but newer versions can be retro fitted.
I'm not a mechanic but operate a 3090 regularly
   / Anyone know MF autotronic transmissions #3
We have one, only it is in a 3120, it has been perfectly reliable.
Biblio,
Please check your private messages. Thanks.
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
2019 GALYEAN...
HELI 5K FORKLIFT (A58216)
HELI 5K FORKLIFT...
New/Unused Quick Coupler (A57454)
New/Unused Quick...
2024 CASE TV620B SKID STEER (A52709)
2024 CASE TV620B...
2014 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2014 Ford F-250...
