12v seat heater?
   / 12v seat heater? #11
The guys I ride with (motorcycle sport touring) wear heated vests and gloves. I think this is likely the most practical solution for active heating. You can get them with controls and thermostats built in and their made ruggedly for motorcycling. I can't remember the cost, but a couple of hundred dollars sounds right.
The other addition could be a motorcycle/snowmobile helmet with a heated visor. The helmet will keep you warm and the heat in the visor will keep it from fogging/frosting up.
I know it was 5 miles through the snow to your school, uphill both ways but...
I wonder how I survived 3 winters in Minot, ND (Minot AFB) in temps down to -47F with only long johns, two pair of BDU's (fatigues) and an arctic flying jacket (parka.) No heated seats, a VW that couldn't defrost the window much less heat the interior, and you had to take the battery out at night to keep it warm inside to be able to crank the next morning. I walked all over the base in all conditions. Youth, wasted on the young who can't appreciate it.
My Kubota (with cab) has a heater par excellence that will toast you when it is 0 degrees F outside if you turn it up.
So far as insulation for the seat... Google on space blanket...
Shopping results for space blanket
SILVER RESCUE SPACE BLANKET EACH $0.85 new - FirstAidMonster.com
Space Blanket $0.99 new - Amazon.com
MTR Mylar Emergency Space Blanket $1.85 new - Med-Tech Resource
These are super cheap and will reflect 90% of your body heat back at you. One rescue blanket (cheapest form of space blanket) could be easily cut up with scissors to make several seat covers. I don't think you could wear out in a single season all the seat covers you could make from just one rescue blanket for a couple bucks. A little duct tape would hold it in place.
Of course it works by refrlecting back your body heat so you need to sit on it before your buttocks get too cold.
Pat
   / 12v seat heater? #12
I just sit on a folded up military-surplus wool blanket... works wonders. :)
   / 12v seat heater? #13
Years ago, there was a round-shaped, camo or orange seat cushion thingy that was marketed to hunters. I don't know if they worked, but they would at least insulate your rear from the tractor seat.
I checked Cabelas, but they don't seem to have them. Not sure if they're still made, nor what they would have been called.
   / 12v seat heater?
They make 12 volt heating pads. I think they are less than $30.I may just have one pinned inside a waterproof jacket. It just seems like someone would have thought of this before now.
   / 12v seat heater? #15
It was called a HOTSEAT and yes it worked. Very well insulated. So well that after you sat on it for a minute or so it actaually felt like it was heated. I suspect it was just a vinyl pillow filled with foam packing peanuts.
   / 12v seat heater? #16
I have had some experience moving snow in the cold too and the very best thing I have used, so far, is a 12 volt electric vest inside my insulated coveralls. Trying to keep warm from the outside will, as others have said, just give you a wet butt. Not comfortable and if you stay out long enough will eventually become a cold wet butt:eek:. Surprising that a small amount of heat, 40 watts, inside your warm clothing will keep you very comfortable. Since the warm up with such a low wattage takes some time I found it was easy enough to just unplug the vest when I became too warm and plug it back in when I cooled off again.
This coming winter will be my first with the heated cab, looking forward to it. The coldest I saw last winter after I got the cab was about -20C (about 0F) and the cab was very comfortable.
   / 12v seat heater? #17
A little off the subject, but not too far. I have to tell you I got a chuckle out of this thread so far. Every time I see the title, I can't help but think about my mother. Every Christmas, when I would ask her what she wanted for a gift, she would always tell me she wanted a heated toilet seat. And I miss her so.
   / 12v seat heater? #18
Sounds like a deer old sole.
On the other note I like a piece of lambs wool for my tractor seat. Adds warmth and cushy for the tushy!!
   / 12v seat heater? #19
I've had minor frostbite on my hands a feet a few times as a kid who stayed out playing in the snow too long. With that in mind, I'm planning on getting some socks and glove liners from this outfit since I put a 12vdc power-port by my seat. If I can keep my hands and feet warm, then I have a shot at doing snow removal.
Gerbing's Heated Clothing // The World's Warmest Clothing!
   / 12v seat heater? #20
Having to plug oneself into my tractor sounds like a hassle. When I remove snow I often switch my backblade from pushing to pulling and back so I am always moving around. I wouldn't want a cord I would inevitably forget I had plugged in. I rarely found the need in CO. I was only cold if my gloves got wet. My feet hardly ever got cold and that was with the warmer temperature Caribou Sorels.
This stuff works really well but is expensive (I have them in my ski boots):
Products | Hotronic - Keeping Feet Warm, Keeping Hands and Feet Dry!
I thought they had gloves too but I don't see them.
The OP is in KY- His weather does not require arctic survival gear, good gloves, boots and layers and he will be fine.
2003 LEEBOY L150 ASPHALT DISTRIBUTOR TRAILER (A52707)
2003 LEEBOY L150...
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58214)
RIPPER ATTACHMENT...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
Deere 35G (A53317)
Deere 35G (A53317)
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
