Rim Guards dealers in my area- S.Carolina
   / Rim Guards dealers in my area- S.Carolina #1
zman007007
Gray Court,S.C.
B7100HST-E
I am looking for a rim guard dealer close to me. I live in Gray Court, S.C. in Laurens county. The rear tires on my tractor are 8.3 x 16. How much should I expect to have to pay for this procedure? The tires do have tubes in them and no known leaks. thanks zman
Thanks for the info and link Whitedogone. I will call the toll free # and check it out. zman
   / Rim Guards dealers in my area- S.Carolina #4
Anitfreeze and water would sure be alot less money, but then again ya cant take it with you. Seriously though, with the tubes in there you wouldnt have and corrosion issues and the sierra brand is supposedly non toxic?
according to the chart on the link he sent it will only take about 12 to 13 gallons to fill each tire, so it wont be too bad. zman
   / Rim Guards dealers in my area- S.Carolina #6
I filled mine with blue windshield washer fluid using a cheap valve from TSC and a old bilge pump from a boat. Total cost was $50 and took about 2 hours and 40 gallons, 20 per tire, to do it. Just get the blue stuff on sale for about a $1 per gallon.
Chris
will this stuff rust the rims tho? in case of a leak
   / Rim Guards dealers in my area- S.Carolina #8
WWF will not rust your rims. The old Calcium would but it took 30 years to do so.
Chris
   / Rim Guards dealers in my area- S.Carolina #10
rim guard will weigh more / gal
You are right it does weigh more. WWF weighs about 8.5 pounds per gallon while Rim Guard weighs 10.7 pounds per gallon. In my case it took 20 gallons per wheel or 40 gallons total. So WWF weighed in at 8.5x40=340# and cost $50 Rim Guard weighed 10.7x40=428# and would have cost over $300. Cost was $6.50 per gallon plus set up fee. I was willing to give up 88# for a $250 savings. The poser is only talking about using 24 gallons so the weight loss is only around 40#.
Chris
2007 Hyundai Sonata GLS Sedan (A54815)
2007 Hyundai...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A53421)
2025 Kivel Forks...
2018 Caterpillar 308E2 CR Midi Excavator (A52377)
2018 Caterpillar...
2012 Cadilac SRX SUV (A53424)
2012 Cadilac SRX...
