Jinman,
I totally understand where you are coming from putting in a lot of effort to get the garden close by the house. Sometimes you jsut want to take your coffee and walk through and just enjoy it and when it is far away from the house you miss those quiet moments.
I know I am a couple pages back from the original post but wanted to let you know that your zuccini flowers are valuable. If you contact any upscale restaurant they will buy them from you. Also you can freeze them. Just pick them when they are nice and big and put them in a zip lock bag and freeze them. You jsut make a simple flour and water mixture, about the thickness of pancake mix, and fry them in olive oil. Yum yum.
Here is another really good recipe you might enjoy with all your veggies.
Take Pita Bread, take the tip of a serrated knife, poke the knife into the pita bread about 3/4 of an inch and go all the way around the circle of the bread. Now you can easily seperate the pita bread into two "tortias" for lack of a better word. Place these down with the smooth side up on a flat pan like a cookie sheet.
Slice your peppers paper thin and place on the Pita bread, add very thin slices onions, add some crumbles of Fetta cheese, oyu don't need that much Fetta. Add some black Greek Olives, and with your thumb over the opening of your bottle of olive oil quickly circle the Pita and add a few drops of olive oil. You don't need that much oil, jsut a little. Now get some black Tapenade you need only about a level teaspoon don't add to much. Smear black tapenade on top of everything. Bake in a hot oven of around 400 degrees for oh maybe 15 minutes or so. Just keep looking at it and you will know when it is done. Put it on a cutting board and using a pizza cutter cut into quarters and serve hot. It is a very good recipe for green and red peppers and you can use yellow ones also. I have not had bananna peppers in a long time but I am just guessing here it would not turn out that great with bananna peppers. It is a good recipe to make when you ahve a lot of really fresh great tasing peppers.
You might have a challenge finding tapenade it would be sold in a food specialty (read- fancy) store. Your tapenade once opened will last a couple months in the refridgerator but the jars are very little so chances are you will use it up way before it would ever go bad. Having the tapenade on top really makes a difference in the recipe so it is worth the effort to try and find it if you can.
We hand pick our olives for our tapenade and in the spring next year we will be exporting it to the states. I got a chemist to do the nutrition label for me so I am all set to go. In a few weeks we will pick our Salonenque olives for the green tapenade and in December we will pick Bouteillan olives for our black tapenade. Olives are just like banannas in that all banannas start out green then go to yellow and eventually all turn black. Olives are the same way. All olives start out green then they all turn black. The difference int he green and black tapenade is when you pick the olives. Then we take them to a mill that specializes in curing them and then we haul them to a food processor to be made, using our recipe, into our tapenade.
