skid steer attachments on tph
   / skid steer attachments on tph #1
rus_geek
Gold Member
Poniatowski, WI
Bobcat CT225
Searching isn't my strong suit this afternoon, or this hasn't been discussed before. I'm thinking there should be a TPH mounted skid steer style quick-tach that would allow one to use various attachments (especially forks) on either the loader end or the TPH end.
-rus-
   / skid steer attachments on tph #2
They are out there........... as well as a SS to three point adapter to allow you to use three point attachments on your front end loader (such as a landscape rake).
   / skid steer attachments on tph #3
delta hitch is similar, but the 3 point has to be different to allow for the PTO shaft
   / skid steer attachments on tph #4
Many of the skidsteer attachments are built for high-volume hydraulic pumps. You might be disappointed unless your tractor's hydraulics are up to the task.
   / skid steer attachments on tph #5
Here are some..
   / skid steer attachments on tph #6
You need three point to MALE Skid Steer. Then SK implements could be fitted to the back. I havent seen these but would sure like to have one.
larry
   / skid steer attachments on tph #7
I bought mine from Millonzi a couple of years back. They're out of biz now, unfortunately.ot sure who fills that bill currently. Used it for pallet forks with heavy skids of firewood.
   / skid steer attachments on tph #8
Seems like it would be pretty easy to make if you take the ATI kit or some such and weld it on a frame with pins.
I've thought of doing the reverse with a QA female plate and parts from a harbor freight QA - island tractor has something similar from Millonzi. It puts 3ph on the FEL.
I'm happy enough to just run Skidsteer stuff on the FEL. Yeah, it requires a big tracotr, but only a big tractor has the hydraulics to make SS stuff work. Otherwise you are better off getting a skidsteer type implement that's been modified to run off the PTO.
JJ, I am consistently impressed with the pictures you put up! Your pic library (or search skills) are impressive! (as is your knowledge)
   / skid steer attachments on tph #9
Here are some..
Far as I can tell those are all made to go on a male skid steer connection and convert it for 3pt implements. Thats backwards... He needs it to go on a 3ph and convert it to use SK implements.
larry
   / skid steer attachments on tph #10
larry
The original poster said for front and back. I have not seen the the 3ph conversion, that allows one to convert from 3ph to male skidsteer. Most skidsteer attachments are made to be pushed. I made an adapter to go from skidsteer to 3ph, and also to use Power-Trac attachments.
2019 Bobcat T590 (A50123)
2019 Bobcat T590...
UNUSED SWICT 72" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 72"...
2007 CATERPILLAR 330DL EXCAVATOR (A51246)
2007 CATERPILLAR...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
CRESCENT  MANIFOLD TRAILER (A53843)
CRESCENT MANIFOLD...
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A53473)
2015 Freightliner...
