K&N Air Filter for CK30
   / K&N Air Filter for CK30 #11
So it will most likely do nothing to your tractor but it is a lifetime cleanable filter that is much cheaper then buying replacements...[/quote]
Is it really cheaper? If you buy the K&N cleaner stuff and then their oil that goes on the filter to make it work, is it really any cheaper than a std paper replacement filter? I don't know as of today, but years ago it was not.
   / K&N Air Filter for CK30 #12
MtnViewRanch said:
With that said, adding air to a diesel engine does not make more power without adding fuel.
As is true with many all-encompasing statements, this is not always true. It has been proven time and time again that adding a turbocharger to a mechanically injected diesel will increase HP without touching any injection pump settings.
   / K&N Air Filter for CK30 #13
RickB, I guess that I should have quoted only the highlighted area as I have just taken care of that. I was not responding to the air to diesel engine thing. Sorry :eek:
   / K&N Air Filter for CK30 #14
After a re-read, I see that was actually a quote from Dmace, not you. Not sure how I made that mistake, but I did. Sorry about that.
My response stands, though.
2022 CATERPILLAR D3 LGP CRAWLER DOZER (A52709)
2022 CATERPILLAR...
2020 Ford F250SD (A55973)
2020 Ford F250SD...
LOT: Fill-Rite Pump, Fuel Transfer Tank, Tool Box (A59076)
LOT: Fill-Rite...
CANOE (A56859)
CANOE (A56859)
2018 KENWORTH T800 HOTOILER (A58214)
2018 KENWORTH T800...
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
