bx 2350 loses power after 20 minutes
   / bx 2350 loses power after 20 minutes #1
mark fox
kubota bx 2350
after mowing for approx. 20 minutes tractor will lose power and stall, runs on upper temperature range but will start right up again after cooling and run again approx 20 minutws have changed fuel and air filters coolant is fine and radiator clean any ideas?
   / bx 2350 loses power after 20 minutes #2
Only thing I can think of, if you have good clean fuel, maybe the vent in the fuel cap is plugged. Next time it stops, try taking the fuel cap off and see if that will let it run.
   / bx 2350 loses power after 20 minutes #3
This exact thing happened to me when my wife added regular gas instead of diesel to the tank.
   / bx 2350 loses power after 20 minutes #4
My first thought was also filters but, water in fuel? Any trash in fuel tank that is getting pulled down to the outlet and cutting off the fuel and when tractor is sitting vacuum releases and the trash floats clear.
Had a wasp do that to one of mine. Hard to see. When it cuts off with you try removing fuel filter and see if you have a good fuel flow. If you do look elsewhere. At same time look in air intake before the filter to see if any pest lodged there or trash. Also your fuel cut off is fully open? Had one of those to get damaged and it would look open when not fully open.
   / bx 2350 loses power after 20 minutes #6
What you need is three tractors and then just rotate between them!:p
UNUSED AGT QUICK ATTACH AUGER SET (A51244)
UNUSED AGT QUICK...
2017 Kia Optima LX Sedan (A50324)
2017 Kia Optima LX...
(4) 320 x 90 R50 Tires and Rims (A50514)
(4) 320 x 90 R50...
2014 BMW 3 Series (A50324)
2014 BMW 3 Series...
2020 CATERPILLAR 320GC EXCAVATOR (A51242)
2020 CATERPILLAR...
E-Z Trail 680 Adjustable Head Cart (A50514)
E-Z Trail 680...
