Volume of tubing
   / Volume of tubing #1
Wineslob
Member
Northern Kaliforniastan
Quick question, anyone have a formula to determine the volume of rectangle tubing?
I have some pieces of 6" X 4" X 3/16 wall steel tubing (O.D.) that I want to use as an oil reservoir. I can't seem to find anything to determine the volume in gallons per ft.
   / Volume of tubing #4
Someone check me but is it 1.0591792 Gals/foot? same as woodchuckcanuck two posts below!!!
Edit: I love the "edit" feature, where you can go back and "fix" things... I'll try and check it again.
Edit (again): Ah, two walls, duh! 1.059 gals... so, yea... about a gallon!!! :D
   / Volume of tubing #6
L = 4-(3/16+3/16)
L = 3 5/8 = 3.625 inches
W = 6-(3/16+3/16)
W = 5 5/8 = 5.625 inches
Area = 3.625*5.625
Area = 20.390625 inches
Volume per foot of tubing = 20.390625 x 12 inches
Volume per foot of tubing = 244.6875 cubic inches
1 cubic foot is approximately 7.48 gallons (according to wiki link)
1 cubic foot = 1728 cubic inches
Volume per foot of tubing = 0.1416015 cubic feet
Gallons per foot of tubing = 0.1416015 x 7.48 gallons
Gallons per foot of tubing = 1.0591792 gallons (about 1 gallon)
That's my story and I'm stickin' to it. :)
   / Volume of tubing #7
Egon, what was your answer?
Oh I didn't even try and crunch the numbers. Didn't know if it should be Imperial measure, American gallon or Metric??:confused::confused: and I was wearing socks and didn't want to take them off!:eek:
   / Volume of tubing #8
Roughly a gallon per foot. You could have measured off a foot then poured liquid into it until you hit your 1' mark. I don't like to use my brain. My one brain cell left sits in a rocking chair rocking back and forth all day muttering utter nonsense. :confused:
   / Volume of tubing #9
Sounds like me. I just poured bar oil in the gas tank on my chainsaw. I had the saw 180 d turned from how I usually do it. Caught it before I started it.
Then after I filled the bar oil I left the cap off. Could not figuire where all that oil was coming from. Talk about a senior moment.
   / Volume of tubing #10
I left the cap off
I have a tendency to leave the fuel cap off. Irritating when the pants get soaked up with fuel and you have to stop and wash them.:eek::eek:
2008 Ford F-550 Flatbed Truck (A52377)
2008 Ford F-550...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53472)
Michelin CARGOXBIB...
2019 JOHN DEERE 8295R LOT NUMBER 181 (A53084)
2019 JOHN DEERE...
2016 Hino 195h Truck, VIN # JHHSPM2H6GK001602 (A51572)
2016 Hino 195h...
