What is this type of hookup called?
   / What is this type of hookup called? #1
RayCo
Chester County, PA
Kubota BX24, Case 580 Super L
   / What is this type of hookup called? #2
Only time I've seen something like that, it was a one-wheel trailer behind a motorcycle. It let's the trailer lean along with the bike. That one looks to be on a four-wheeled vehicle, so I'm not sure that applies, but maybe it's still a one-wheel trailer?
   / What is this type of hookup called? #3
One of my customers uses something like that behind his 2500 Dmax. He is a avid hunter and it will literally allow any angle between the truck and trailer without binding. I guess he needs it because he has a big pusher type front bumper and a winch that are well worn so he must get in some crazy places.
A standard ball set up will only allow about 15deg of flex, a Bull Dog give maybe 25 deg.
This is only the second one I have seen. I believe he has a custom made weight distribution system that uses the same joints and 3/4" all thread in place of chains.
Chris
   / What is this type of hookup called? #4
I like it kind of a modern style pintle hook. I have never seen one like that but can see the advantages of it.
   / What is this type of hookup called? #5
I'm not familiar with but know of the existance of shock absorbing hitches. Cushions the push/pull of the trailer to the tow vehicle. ????? MikeD74T
   / What is this type of hookup called? #6
It is for off road use, pretty much unlimited articulation. Get crazy enough with a standard ball mount and you can bend things or even pop it off.
   / What is this type of hookup called? #7
I saw one of those in a "FOUR WHEELER" magazine a few months ago. It was an offroad trailer for a custom Jeep. It can move practically anywhere.
Kyle
   / What is this type of hookup called? #8
I have heard of sticking a 1 wheeled traier behind a 4wheeler.
I'm guessing it isn't for offroad, as it wont let the trailer twist with resect to the towing vehicle, unless the trailer suspension has all sorts of articulation.
ps. nevermind, I see were it might let it twist.
   / What is this type of hookup called? #9
It looks very similar to the ones used on motor homes to pull cars ect. They are fully articulating and far less likely to accidently disconnect.
I'm glad I'm not the paranoid type to interpret that to mean that my typical ball mount trailer is likely to disconnect. :)
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2015 INTERNATIONAL 4300 BOX TRUCK (A51222)
2015 INTERNATIONAL...
2013 Chevrolet Sonic Sedan (A50324)
2013 Chevrolet...
1994 Mack CH613 T/A Wet Kit Day Cab Truck Tractor (A49461)
1994 Mack CH613...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2018 GENIE...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
