massey ferguson overheating issue
   / massey ferguson overheating issue
ok so now i dont know if i have a overheating issue or not...i flushed radiator with NAPA flush and put a new cap on radiator. i also pulled off top radiator hose while engine is running and the water pump is definantly pumping. so i drove the tractor with bush hog running for about 25 minutes and it went back up to about 90-95 degrees celceus....BUT this time when i shut the engine down it did not come spewing out the overflow. wonder if the new cap made that difference? is 90 degrees celceus too hot when tractor is under load? antifreeze is not comming out around cap or out of overflow now.
   / massey ferguson overheating issue #12
90-95 degrees celsius = 194-203 degrees fahrenheit.
It kind of depends on where you temp sender is located as to whether or not the temps you stated are high or not. If it's coming out of the radiator that hot then it may be an issue but if it's going into the radiator at that temp then in my opinion it's definately not.
You could remove the t-stat, see what temp is stamped on it. I'd guess it should be a 180 degree stat. If it's a 195, maybe you could put a lower degree stat in it.
Maybe the gauge isn't accurate! I've seen gauges read 5-20 degrees off.
the manual says anything above 100 degrees Celceus would be considered overheating on this tractor so maybe im alright afterall
   / massey ferguson overheating issue #14
It may indeed be running hot. That being said, do a search on this site for "normal operating temp" and check out about the first three. Some of these explain in more detail what I'm getting at.
I'm not very articulate when giving explanations on certain processes.
   / massey ferguson overheating issue #15
The guage is in celcius because the tractor is built in Japan. I have the Japanese version of this tractor and had the exact same problem. A head gasket fixed it even though the old one looked OK.;)
Eugene
formerly buppy69
   / massey ferguson overheating issue #16
Eugene
formerly buppy69
Gee you know how to spoil a party :eek:
   / massey ferguson overheating issue #17
Sorry:rolleyes:
Eugene
formerly buppy69
tractor still running a little hot under heavy load. i was bush hogging tall grass today with it and it got up to about 110 degrees celceus after about 30-45 minutes of use. seems to be better though. Anyone ever try rigging up an electric fan in front of radiator? i have on left over from a car i used to have...thought i might put it on a toggle switch.
   / massey ferguson overheating issue #19
save the bandaid.. find the real issue before you roast the engine..
soundguy
ok found problem....took radiator to radiator shop and had it pressure tested. They said it is definantly clogged. Gonna charge me $65 to fix it. If this isnt my problem then i give up! haha
2015 Chevrolet Silverado 3500HD Ambulance (A52377)
2015 Chevrolet...
2019 MACK PINNACLE P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
KUBOTA M7-132 LOT NUMBER 31 (A53084)
KUBOTA M7-132 LOT...
Utility Trailer (A52377)
Utility Trailer...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
