Need to find Used Yanmar YM276 parts very badly!
   / Need to find Used Yanmar YM276 parts very badly! #1
benkohn
A couple of days ago I wrote trying to find two new parts which are springs for my Yanmar YM276. I did receive a lot of help but it became clear that there was NO-ONE ANYWHERE WITH BOTH NEW! So if anyone anywhere knows anyone with a YM276 that they are neither using running nor operating any longer PLEASE write me as I need these parts very badly. The parts are two springs that run the Hydraulic Relief Valve and Hydraulic Delay relief Valves. The actual parts numbers needed are 194446-24540 And 194446-24550. These parts are quite easy to remove as they are on the top mechanism nearer the front of the transmission and both parts are small (less than 5 inches) and light too. I will be happy to supply copies of the parts diagrams that are quite clear and assist in other ways too. Please do let me know if you might know where a machine is that could supply these parts!
Ben Kohn
Florida
benkohn@prodigy.net
   / Need to find Used Yanmar YM276 parts very badly! #2
Are your springs broken? If so how many pieces? It seems to be you could get someone to tig weld it back together if its broken and get some more use out of it.
Well after a few minutes of mulling this over im thinking that the heat would mess up the springyness of the metal. Then again if its allready broke you dont have much to loose if it doesnt work.
I did see your other post and If i were you i would go ahead a buy the spring that was still available. For the other spring you might be able to find one of similar deminsions and see if it will work. Using the internet you can find all kinds of stuff.
Just found this on the net ----newcombspring.com---- , there website says they make prototype springs and short runs, you might get lucky and get someone to answer the phone that is willing to help.
This one looks primising --------tricorindustries.com---------
   / Need to find Used Yanmar YM276 parts very badly! #3
How many of the 150, or so, parts dealers have you called so far?
Ken:
I had thought about trying to repair it but that will be a very last choice since a used one is still far superior. Certainly the springs both are highly tempered by the look and feel. I have searched springs but this is touchy because they have used two springs for exactly the same function. The larger one is likely supplemented by the second one. I believe it is because they could not get a spring of the modest diameter strong enough to do the whole load. They just added another inner one to help it out. This suggests the used spring is very close to capacity for the size. Lastly it would be relatively easy with a new spring set to measure the characteristics (just like in high school physics lab) and then find a matching spring from a producer. Unfortunately I can not do that as I neither have a good spring nor can I get a new one to test. I may even soon try to get in contact with yanmjar to see if by chance I might be able to get the original specifications used for both those springs but that is real ifey.
Thanks for the spring makers' info. I will try to post when done to share the wealth.
I did think the same but it was real weird cause every one of the four dealers I have talked with suggested darned clearly in a indirect fashion they did not even want to be involved. Yes I know these are low cost parts but they said ALL FOUR almost the same words "There are no springs like this available!" I had to press them hard and repeatedly that some might be upon the shelf somewhere before any would even conceed that was EVEN POSSIBLE! It was real strange!!!
Please share any real experience you have with Yanmar dealers so I know it might be worthwhile to make all those calls? There is possible and then probable! It is only the fools that bet on possible.
ben
   / Need to find Used Yanmar YM276 parts very badly! #6
The 4 dealers can only tell you what THEY have on the shelf and what is in the main Yanmar warehouses. They do not have any way to know what is on the other 150 dealers' shelves.
Aaron
Hoye Tractor Parts
Contact Us
(940)592-0181
   / Need to find Used Yanmar YM276 parts very badly! #7
ben
I'm talking about Yanmar's state-by-state listing of authorized parts dealers, not aftermarket dealers, who have 30-year-old NOS parts on the shelves, most of whom will only sell to "made for US" tractor owners such as yourself. I recall one dealer a few years back who put her entire inventory on the market.
   / Need to find Used Yanmar YM276 parts very badly! #8
ben
You didn't here that from this dealer, I told you I would get you the one that is available from Yanmar, but I can't get the one that Yanmar no longer sells.
Danny
Norm:
Thank you but have you had direct success with what you suggest? Please let me know of examples from your own experience or of direct friends where they located parts that were "unavailable" by other means by chasing down the 150 dealers you suggest checking with. Isn't that what you have suggested to do? Is it what you would recommend or just an idea to toss around like welding the springs back together?
I am not trying to be at all terse but I never recommend to others "what I would not myself do" otherwise others would be led to take me as callous flipant and unreliable. I would be programming them to not even try to listen to what I say. Boy would that be far from my best interests and intentions!
ben
   / Need to find Used Yanmar YM276 parts very badly! #10
they said ALL FOUR almost the same words "There are no springs like this available!".... It was real strange!!!...
Now that's a funny interpretation of what they told you! :p
Look, you're the one with almost-a-tractor. Maybe some dealer will have that part to make your tractor whole. If four dealers told you there is no central registry of who has what, then it sounds like you still have 146 dealers to contact.
2016 Ford F-550 Altec AT37G 37ft Insulated Bucket Truck (A52377)
2016 Ford F-550...
2025 K5436 UNUSED (5) Wire Mesh Panels (A53117)
2025 K5436 UNUSED...
2015 GREAT DANE ETL-1114-31053 REEFER TRAILER (A53426)
2015 GREAT DANE...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A53117)
2025 K0720 UNUSED...
2018 International Durastar 4300 Altec Forestry Bucket Truck (A51692)
2018 International...
2017 GMC Sierra 1500 Elevation Crew Cab Pickup Truck (A51692)
2017 GMC Sierra...
