murray rear engine mower ?
   / murray rear engine mower ? #1
stevend
HI, I bought a murray rear engine mower in great shape guessing made in the early 2000's.
The problem is the engine wouldn't turn over. Took the top cover off and found out a big crack running the length of the case and a chunk missing. The engine is junk. Would I be better off finding a good used engine or buying a new engine?
thanks
   / murray rear engine mower ? #2
For your use I kind of doubt that there is such a thing as a ''good used engine''. I would look for a new one and avoid the problems that you will get with used, Sometimes used means abused.
Hi, I guess I will look for a new engine. Is there a different engine of a different horsepower that would fit instead of a tecumseh 10hp? Where would be a good place to search for a new engine?
thanks
   / murray rear engine mower ? #4
If you have a Sear's service center near you you should be able to pick up a replacement. Or check local small engine repair shops.
If you go for a bigger motor just beware of different mounting pattern and cable hook ups.
Hi, Have a problem with the other 10 Horse murray we have. Just started yesterday,When you start it up it will shoot out a little puff of smoke. After letting it idle for 30 seconds it starts smoking burning oil out of the exhaust and between where the muffler meets the engine. What would cause it to be smoking like this? Could there be a hole in the piston or some other problem?
thanks
   / murray rear engine mower ? #6
Can you provide a little more information please?
Did you check the oil level before or since you started the mower? If not, would you please and report back. Why check the oil level? If your mower's fuel supply is gravity fed there is a good chance that fuel leaking past the needle valve in the carb has allowed gas to add to the level of the crankcase oil. This can cause the oil/gas mixture to enter the cylinder and be burned during combustion causing the smoke you are seeing. While you are checking the oil level, give it a sniff. Does it smell like gasoline?
Please let us know what you find and we'll put our collective heads together to make additional suggestions.
Hi, I checked the oil it doesn't smell like gas. The level is half way between the add and full mark. I just started it up it doesn't do it nearly as bad as before. There still is a little smoke coming from between muffler and engine. After I shut if off you can see smoke coming off the muffler for about a minute.
   / murray rear engine mower ? #8
sounds like a broken, or worn out piston ring to me zman
John Dozer JD650 (A51691)
John Dozer JD650...
MAHINDRA 2810 TRACTOR (A54756)
MAHINDRA 2810...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2022 Allmand Maxi-Lite II 20kW Towable Light Tower (A52377)
2022 Allmand...
2025 78in Rock Bucket Skid Steer Attachment (A53421)
2025 78in Rock...
2018 CHEVROLET SILVERADO 2500HD (A53843)
2018 CHEVROLET...
