help ID this mysterious John Deere part
   / help ID this mysterious John Deere part #11
This is what is known in the trade as a "POCKET PART." If after reassembling a mechanical assembly there's a part or parts left over and the assembly seems to work OK without them then you put the extra part(s) in your pocket and try not to worry about it while maintaining plausible deniability that you did so.
Pat
   / help ID this mysterious John Deere part #12
I think its something that just fell in. My buddy was changing his oil on a brand new truck back about 10 years ago and he heard something drop that was metal when he open the drain plug. He filtered the old oil and got a ball bearing about 3 times the size of a BB. He called the dealer and they sent a mechanic out and said do not worry about it, its not part of the engine. Anyway he drove that truck for 4 years and zero engine issues so it must have been a ball bearing from the plant or assembly tool.
Chris
   / help ID this mysterious John Deere part #13
End shim for some gear-shaft? I'm with the manufacturing debris crowd though! ~Scotty
   / help ID this mysterious John Deere part #14
Either manufacturing debris or "repair debris".
When Pat called it a pocket part I thought he was going to state that it's something that came out of a shirt pocket in the process of performing some other repair.
   / help ID this mysterious John Deere part #15
IPF- If that were the case, He would have probably found my cell phone in his crankcase after i was helping w/ engine repair!! ~S
   / help ID this mysterious John Deere part #16
Maybe it's not a mysterious John Deere part afterall. Maybe it's a mysterious Motorola part.
   / help ID this mysterious John Deere part #17
I couldn't see the cuts good enough, but it looked like it was cut with a waterjet. If it was, it was probably dropped in at the manufacturer.
PALLET OF SCAFFOLDING PARTS (A52706)
PALLET OF...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2018 RoGator 1100C (A55302)
2018 RoGator 1100C...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50322)
Pitts Tri-Axle RGN...
1995 GMC CHIPPER/BUCKET TRUCK (A54607)
1995 GMC...
