FINALLY!!! Found a place for hints on small diesels...gator help please!!!
   / FINALLY!!! Found a place for hints on small diesels...gator help please!!! #1
kinzepower
I have a Deere gator XUV that I would like to turbo it and get it to around 40 dependable horsepower...or more.
Anybody have any helpful info where to start?
Need a properly sized turbo, and modify the pump.
It has a 854cc yanmar that high idles at 3400rpm i believe, and has 24.6 hp.
Thanks.
   / FINALLY!!! Found a place for hints on small diesels...gator help please!!! #2
There are several who have turbo'ed various models here on the forum. If you search the Yanmar section with the word "turbo" you will find at least 3 threads where guys have turboed their Yanmars, that I can remember. Recently in this customization forum recently a guy turbo'ed a NH Ford. There also was recently a thread with a guy who made garden tractors for tractor pulls. he was getting huge amounts of power out of the small engines.
"Dependable" is going to be a key word. "Longevity" is another. I believe your goal would be attainable, but I am not sure that the result will be "dependable" or long lived. Temperatures are the critical factor, especially TIT. Secondly, will the drivetrain designed for 24-26 hp be up to the requirements of 40 hp?
There is a JD section also so maybe someone there has done what you want to do. I wish you luck and do keep us posted.
Mike
   / FINALLY!!! Found a place for hints on small diesels...gator help please!!! #3
Thanks.
Here is a good place to hang out:
dieselgardentractorpulling : Diesel Garden Tractor Pulling
Don't use a turbo any bigger than a Mitsubishi TD02, make sure it's a twin scroll. Columbus Diesel Supply and Sheid's modify these pumps and injectors.
Here is a Yanmar 3 cyl just a bit bigger than yours:
YouTube - 3 cylinder diesel goes 350 feet
   / FINALLY!!! Found a place for hints on small diesels...gator help please!!! #5
There was a guy on ebay selling ready made kits for the Kubota RTV, more for high altitude use.
40 hp and having it live isn't too much of an issue. Common sense is the rule. We get over 100 hp out of a 1.12L but that's a different story.
   / FINALLY!!! Found a place for hints on small diesels...gator help please!!! #6
kinzepower
Here is a link to a person that has put together a kit to turbocharge a Rhino small diesel he is using a similar IHI RHB3 turbo that I used on my Ford 1210.
Kubota Rhino Small Turbo RTV1100 Pieces Turbocharger - eBay (item 230379904336 end time Sep-25-09 20:18:14 PDT)
I nearly got 30hp when you do the math converting from PTO hp out of a factory rated 16hp tractor with this size turbo and small fuel pump adjustment. So the 40hp will be easy to get out of the 24hp Yanmar . A similar displacement turbocharged diesel engine from Briggs & Stratton/Daihatsu. Makes 34hp all day long in the surface prep equipment that I build.
Good luck with your project.
Jay
   / FINALLY!!! Found a place for hints on small diesels...gator help please!!! #7
Why not just buy a Rhino, or a Ranger? You can get them with 800cc engines, and a CDI box makes them a rocket, and they have a warranty! :cool:
   / FINALLY!!! Found a place for hints on small diesels...gator help please!!! #8
Get a Bad Boy Buggie all electric model XT that has 40 hp motors
Well, I farm and use my gator for heavy work that so far, only the gator can handle. I challanged a Rhino to a pin to pin pull off and not only did I pull him backward, he had some big $ repairs to do after the abuse.
The gator is bullet proof as a worker, that is my main concern. If I could add some power, I could work hard and play as hard as the lightweights as well.
UNUSED FUTURE 16" AUGER (A57193)
UNUSED FUTURE 16"...
PALLET OF MISC ROOFING FELT ROYAL GOURMET CC1830F (A57192)
PALLET OF MISC...
ACS 104" HYD PIN ON PIPE GRAPPLE (A52707)
ACS 104" HYD PIN...
UNUSED FUTURE FT-ZP20 20' X 30' GARAGE CARPORT (A57193)
UNUSED FUTURE...
Metal Bigfoot with Flag Lawn Art (A55853)
Metal Bigfoot with...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
