Telescoping hydraulic cylinder 4 dump trailer
   / Telescoping hydraulic cylinder 4 dump trailer #11
Here is my hair-brained scheme. You could simulate a telescoping cylinder by connecting two cylinders together. Put the rams going opposite directions and tee off of your lines. I'll see if I can find a minute to sketch up the idea and post it.
   / Telescoping hydraulic cylinder 4 dump trailer #12
Here is the sketch...
140990d1253901800-telescoping-hydraulic-cylinder-4-dump-mock-telescoping-cylinder.jpg
   / Telescoping hydraulic cylinder 4 dump trailer #13
I never thought of that, but I wonder on the stress it would put on the cylinder end caps, etc. For light work that might work.
   / Telescoping hydraulic cylinder 4 dump trailer #14
I'm sure there are ways to improve on the idea. You could even put a "S" shaped piece between the cylinders that fits the clevises and takes the stress. You could also build a box of sorts that the bases fit into.
That's what brainstorming is all about. Everyone throws out their mediocre ideas, and hopefully a superior idea is born in the midst of it all.
   / Telescoping hydraulic cylinder 4 dump trailer #15
To me the liner idea seems the easiest. Is the trailer to large for a pickup liner? They are not as popular now and can be picked up cheap.
Dean
   / Telescoping hydraulic cylinder 4 dump trailer #16
The liner is the best idea. You also have to consider how tippy it gets when you get it up high in the air and the material doesn't slide out. I have seen semi trailers full of gravel get a little tippy and that looks like it could get ugly in a hurry.
   / Telescoping hydraulic cylinder 4 dump trailer #18
I think you will bend the rods with that setup-unless they are super big.
The other option is to put the cylinders side by side vs. one on top of the other. You'd have to move one or both brackets.
   / Telescoping hydraulic cylinder 4 dump trailer #19
The problem with either setup is the load is not linear to the mounting pins. Look at the modified picture below:
   / Telescoping hydraulic cylinder 4 dump trailer #20
Forklifts use a setup similar to this. They use 2 upright cylinders and one inverted all welded together. That's how a lot of them get the telescoping mast.
2010 Chevrolet Malibu Passenger Car (A51694)
2010 Chevrolet...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
2012 JACK COUNTY 130BBL VACUUM TRAILER (A52472)
2012 JACK COUNTY...
2019 Ford E-450 Super Duty Passenger Bus (A51692)
2019 Ford E-450...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52748)
NEW 2025 Load...
