PDF Tech. Manual File Name? 3x20 series
   / PDF Tech. Manual File Name? 3x20 series #1
HawaiiOrganic
Member
Anyone know the name of the file that JD ships for :
3120, 3320, 3520 and 3720 Compact Utility Tractor w/o Cab
Part # TM2138CD
And WTF is up with that file costing $5 more than the manual that includes the cab?!
Just bought a used 3120, and the last owner beat that thing from all sides in less then 200 hrs.
   / PDF Tech. Manual File Name? 3x20 series #2
The price difference is probably because of the extra transmission info. Open station 3000 20 series tractors could be had with hydro in all versions and power reverser in 3320 and 3520 and then later on the auto hydro. That would be my guess. Cab versions are hydro only.
   / PDF Tech. Manual File Name? 3x20 series #3
Compact Utility Tractors 3000 Twent-TM2138.pdf
Dang, still couldn't find a copy. Whatever happened to free information? I suppose I'm not the first one to feel bitter about spending 20 grand and having to pay for the book on how to make it keep working. :confused:
   / PDF Tech. Manual File Name? 3x20 series #5
Welcome to tractors. Proprietary service info isn't free, and probably won't be any time soon. Dealers are charged exorbitant prices for this info that they are required to have ( and certainly should have), often for machines they will never sell. Manufacturers aren't going to give the end user a free ride, either.
   / PDF Tech. Manual File Name? 3x20 series #6
You can get the owners manual free, But not a FSM(factory service manual). No OEM that I know of will do that whether it's cars-trucks-tractors-or heavy equipment.
The FSM on CD is $75.00, It will pay for itself the first time you use it.
JD Technical Documentation
   / PDF Tech. Manual File Name? 3x20 series #7
Buy the CD. It is worth it. Trust me. It is worth it even if you never have a problem.
   / PDF Tech. Manual File Name? 3x20 series #8
does the technical manual show how to get the cap off the steering ram?
   / PDF Tech. Manual File Name? 3x20 series #9
No, it does not because JD uses cylinders with a welded end caps and considers them non-serviceable, so they only sell a replacement and no seal kits for them.
Some GOOD hydraulic shops can cut the end cap off in a lathe, replace the seals, then re-weld them closed. One such shop is run by a member here, his name is Bill and I suggest you PM him: http://www.tractorbynet.com/forums/members/wdchyd.html
Informational Lot - Financing (A55302)
Informational Lot...
2018 Caterpillar 308E2 CR Midi Excavator (A52377)
2018 Caterpillar...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
RoadTec RX500 Screener (A53421)
RoadTec RX500...
2017 Makita HM1307CB 35lb Demolition Hammer (A52377)
2017 Makita...
2017 HITACHI ZX350LC EXCAVATOR (A53426)
2017 HITACHI...
