Kubota L245 2-wd leaking around gear shift
   / Kubota L245 2-wd leaking around gear shift #1
RPETTY
I have an older Kubota L245 that has just started leaking fluid around the gear shift. I read elsewhere on the internet that it could be caused by a clogged "weep hole" . I cannot locate a weep hole anywhere.... Anybody have any suggestions? PLEASE HELP....
   / Kubota L245 2-wd leaking around gear shift #2
I had this same leak years ago and I think I replaced #13,#21 Hope this page from my manual helps
Thanks, I'll give that a try.. Do you know where the Vent Tube is for this tractor.? I have read several post that suggest that this vent tube may be clogged but all the say is that it is under the seat... I sure can't find it.
   / Kubota L245 2-wd leaking around gear shift #4
Look under the left side of the seat #14
   / Kubota L245 2-wd leaking around gear shift #5
I had a L245DT exactly like yours -- even had a HD snow/dirt plow mounted on front with controls exactly the same as yours -- sure brings back some good old memories. Bought it new in late 70's and had it for 15 years. Never had a problem of any kind.
Regarding the leak, I'd check to make sure the transmission isn't way over full before getting too excited. It's a lot easier to fix that sort of problem and doesn't cost anything.
   / Kubota L245 2-wd leaking around gear shift #6
Got it from my brother about 5 years ago and have had little trouble with it :)Looking foward to plowing snow this winter.
   / Kubota L245 2-wd leaking around gear shift #7
Those photos sure bring back some good old memories from the 70's and 80's when I used my L245DT to plow a lot of snow and mow a lot of grass in upstate NY. On really cold days (zero & subzero) had to use both compression release and glow plugs to get her started but she always started.
Hope you enjoy your L245DT as much as I did mine.
Year: 2013 Make: Kia Model: Soul Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 144,857 Plate: (A51694)
Year: 2013 Make...
2012 Freightliner Cascadia - Class 8, 6x4, Detroit DD13 (A52748)
2012 Freightliner...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
John Deere 1560 No Till Drill (A52349)
John Deere 1560 No...
Unused Delta Crash...
FAKE (A52472)
FAKE (A52472)
