Having a pole building built
   / Having a pole building built
momentarily off topic smfcpacfp, but.... Nice Vette. im a C4 vette guy, but id love a yellow c6
It is a fun car to drive and it is my daily driver for 7 1/2 months a year. It is very comfortable on long trips, get 26 mpg going 10 over the speed limit and has 520 hp when needed.
   / Having a pole building built #32
just a quick throw in about the drain
Here in ND we have the freeze thing big time
most of the time you can put a floor drain in and just pipe it to a dry well outside
sometimes a trap is put in sometimes not
it does get rid of any slop in the spring that comes in
just run the pipe oversize out the wall and dig a couple post holes deep as you can and fill with rock
   / Having a pole building built #33
If you plan to heat it, put radiant tubes in the floor. Ive worked in shops with heated floors and its SOOOOO NICE.:D
I second the over head or inside slider doors if you get any snow. It builds up on the track on outside sliders and takes forever to clear to get the door open in winter. Then the next day you get to do it all over again if it snows. :mad:
Run the phone, cable and anything else while you are trenching.
If no toilet in the shop, at least run a pipe(drain) so you can take a leak inside. Kind of like a mini urinal.
appreciated all of your advice. I started this thread in June thinking that I would have this project done by now, but in fact I just signed a contract for Cleary to build the building yesterday, and they will start around Oct 24 and be finished by Holloween.
Some of your recommendations that I decided to not take: I decided to not use in floor heating for my shop area (1/4) of the building because of the cost verses my useage in the winter. I decided not have have water or sewer due to the proximity to my house, but I think I will have a few pipes put in the concrete for future consideration.
One thing that I wasn't aware of was that the average height of an accessory building in a residential district in my township cannot exceed an average height of 15', even though my residential district requires 10 acre parcels. Since I plan to put an RV in it which is 1" shy of 11', that causes a problem, so we were able to reduce the eave height to 12'6" but in order to meet the height requirement the pitch on the roof is 3.5 by 12.
For you people from the south that probably wouldn't be a problem but where you get 10 to 20 feet of snow a year between thaws, that is an issue. My friends, who are tuned into building here in a snow belt, cringed when I told them that. They felt it should be a minimum of 5 by 12, but I told them that building is engineered to a snow load of 75 pounds per square foot, but they still cringed, and to be honest I am nervous.
I figure that I will need to try to clear the snow off the roof early in the snow season from the ground, but once the snow gets several feet deep on the ground it gets very difficult to clear in that manner.
Why would I be sensitive to this? Well my first garage collapsed under a heavy snow load followed by a hard rain at the freezing point in 1991. So I always get nervous when the snow on my roof gets deep.
   / Having a pole building built #35
MY BROTHER LIVES IN HARRISON MI. I SHOWED HIM YOUR RECENT POST. HE BUILD LOG HOMES AND OTHERS AND HAS DONE POLE BUILDINGS. HE FEELS YOU SHOULD HAVE A MINIMUM OF 5 X 12 PITCH OR IT WILL COLLAPSE. YOU CANNOT STAND ON A STEEL ROOF TO CLEAR IT... HE FEELS WITH THE SNOW HE GETS SOUTH OF YOU, IT SURE WON'T HOLD FURTHER NORTH.
SNOW ON A 3.5 X 12 PITCH WILL NOT SLIDE! TO SAVE SOME HEARTACHE, GO WITH A HIGHER PITCH ESPECIALLY ON A BIGGER BUILDING! IF YOU MUST DO IT, PUT THE DOOR ON THE GABLE END SO ANY SLIDING SNOW WON'T BURY THE DOOR AND BE SURE TO USE 16" CENTERS RATHER THAN 24" CENTERS. HE ASKED WHAT GUAGE STEEL ARE YOU USING? HE SAID YOU CANNOT GET UP ANY FURTHER UP THAN 3-5FT WITH A SNOW RAKE!
   / Having a pole building built #36
I do not know if I would be that worried about the 3.5 pitch roof. That is what I have on my building. I am in NW WI. and I have a dark green roof on mine, it empties itself all winter long. My friend lives in Mercer, WI ( snowbelt area) and he has the same pitch roof which also empties all winter long. It is pretty cool to be standing outside and watch all that snow come off. The one thing I would suggest is to put OSB or Plywood on the bottom 4 feet of the walls behind the metal so when all that snow comes crashing down it doesn't bend up your metal. We just put it behind our wainscoting. What did the guys from Cleary say about the snow load?
   / Having a pole building built #37
Some of my buildings are 3/12 pitch and the snow slides off fine.
   / Having a pole building built #38
I can surely tell you, you cannot walk on a snowy metal roof, you will go for the ride of your life.
About the pitch/slide, there are variables - compass direction is a big one, heat or no heat in the building, heated building with insualted attic space, etc.
I know duffster loves being a contrarian (I too have low pitch metal roof and it will eventually slide) but all other things being equal, the 5/12 roof will clear before the 3.5/12.
I should add, the winter of 2007-08, I had multiple layers of snow ice about 1-2 foot deep, it was so locked up, it wouldn't slide on it's own.
Dave.
2021 JOHN DEERE 648LB SKIDDER (A51406)
2021 JOHN DEERE...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A52377)
2013 Chevrolet...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
