NH T & TD Series Comparisons
   / NH T & TD Series Comparisons #1
pengs68
FARMALL M, FORD 4600, FORD 2000
I have been looking for a low hours used tractor for a while now without much luck. I want to use it for mowing and baleing with a NH 570 with thrower.Today I called the NH dealer about new ones and he recommended the TD 5030 and the TD 80. Just wondering what the differences between the regular T5000 series and the TD are. Also if anyone knows an aprox. price difference. I am looking for a 2WD or 4WD open station without a loader. Thanks in advance.
   / NH T & TD Series Comparisons #2
The T5000 line is the old TL if I recall correctly. The TL was the modern tractor with more electronics and lots of features. The TD was an economy line which was more basic with limited options.
I just got worried when I heard economy, that it wasn't made as well or it was a inferior model.
   / NH T & TD Series Comparisons #4
No, the economy lines are basically just older designs and simpler. that keeps their cost down.
   / NH T & TD Series Comparisons #5
I just got a td 5030. It is 4wd,cab, fel with bucket and hay spike. It was real close to 31,000. It has the 820 loader which doesn't seem as stout as the 33loader on the tn75 I have. I didn't understand the econemy rating either. The service man says they have more sheet metal than their other lines. The only thing that kinda worries me is the engine is a product of nh and case working on design. The tractor has everything I would want on a tractor. Moving up to 5050 is about 3000 more. The loader is 6800. The way i understand it is the 5030 replaces the 80.
   / NH T & TD Series Comparisons #6
The TD5030 replaced the TD80, and what it is a very simple and very mechanical tractor. You will find that it will not have near as many options on it as you will find on a T5000 series. As for the motor they are fine. Most people do not know this but in 2006 Fiat (which ownes NH) built more motors than cat and john deere combined. These TD series are good tractors if someone is looking for a simple tractor.
Bought a FWD TD80. Thay had a TD 5050 on lease return for close to the same price,but decided to go for the new TD 80 which is the same as TD 5030. Should get it in a week or so. Cant wait.
   / NH T & TD Series Comparisons #8
Im also looking at a TD80 with loader, fwd from new albany tractor what did you pay? I will have the tire filled a sunshade and ssl.
CATERPILLAR 259D3 SKID STEER (A50458)
CATERPILLAR 259D3...
2007 Ford Taurus SEL Sedan (A48082)
2007 Ford Taurus...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2011 Ford Crown Victoria Sedan (A48082)
2011 Ford Crown...
2025 12v Diesel Pump (A48081)
2025 12v Diesel...
Toro 30495 Groundsmaster 7200 72in Zero Turn Mower (A48082)
Toro 30495...
