1985 bolens/iseki g274 diesel
   / 1985 bolens/iseki g274 diesel #1
AAlmeter
Any idea of value?
4 wheel drive , loader (new bucket) ,3 point hitch with weight and towbar ,rear pto , 1151 hours
   / 1985 bolens/iseki g274 diesel #2
Any idea of value?
If you could add a photo and describe if all is operational and runs good, or not, that would help a lot.
Everything is operational except the hazards/turn signals. Some wear, but overall its in good shape.
   / 1985 bolens/iseki g274 diesel #4
Well, just my estimate, but the 27HP, 4x4 tractor alone should be worth from $3500 to $4K, and the loader would add another $1000 to $1500 to the overall price...so about $4500 to $5500 in my opinion, without seeing it. Appearance is important for the upper figure, no rusty wheels or torn seat.
   / 1985 bolens/iseki g274 diesel #6
My neighbor has a Bolens G274, and I have worked on it a few times.
Thankfully, we have not needed to buy many parts. It has a simple
crash box tranny, no PS, no ROPS, but it works. I will be trying to sell
it for him for about $4500.
   / 1985 bolens/iseki g274 diesel #7
I can supply most parts new or used for the G274. I have a parts tractor.
   / 1985 bolens/iseki g274 diesel #8
I bought my G274 from an auction this spring for $3,250 with no loader.
   / 1985 bolens/iseki g274 diesel #9
What's a simple crashbox tranny mean Dfkrug..??? is this good or bad....thanks AMPA :):):)
   / 1985 bolens/iseki g274 diesel #10
A crashbox is an unsynchronized transmission. In their simplest incarnation,
they use straight cut gears and require the input and output shafts to be
stationary in order to mesh. This means your tractor has to be at full stop
before engaging any gear, including all fwd and reverse gears. I had one,
a 99 Kubota L2500DT. Ugh.
These seem to be going away for the newest of compact tractors, but there
are many of them still around, even on recently made budget CUTs.
Nowadays, even gear tractors usually have at least a synchronized shuttle
for easily switching from FWD to REV. Some have fully synchro-ed trannies,
and the best gear trannies are shifted with servos and wet clutches. Unless
some think the new CVTs (New Holland) are the best.
Saxon Tri Wing Finish Mower (A52384)
Saxon Tri Wing...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2016 JLG 2032ES Electric Scissor Lift, 369hrs (A52384)
2016 JLG 2032ES...
Heavy Duty Jumper Cables (A51694)
Heavy Duty Jumper...
2019 Bobcat T590 Compact Track Loader Skid Steer (A51691)
2019 Bobcat T590...
Guard Rail Pieces (A51692)
Guard Rail Pieces...
