lhfarm
Good suggestions. I'm debating the size. It can be really cold in central Indiana, with the rare sub-zero days. I like the vapor barrier on the ceiling idea. It has already gotten chilly here (an early fall?) and I doubt I can get going on the insulation for a few more weeks.I just finished insulating my 24X24 grage early this last spring. It is a whole different space now, and requires very little heat compared to what it used to.
Your heat demand is going to be a LOT less after you insulate, so something properly sized for that will surely be inadequate without the insulation, and something sized for no insulation will be way to large once the insulation is up. I am not sure what your coldest temps are and how much wind you have, or your insulation plans, but 75,000 BTU/HR sounds like a LOT of heat for a well insulated space... I heat my home thru the winter in the PNW primarilly with a pellet stove kicking out 12,000 BTU/HR... As mentioned, best to start with the ceiling, but untill you get to it, a visqueen vapor barrier stapled across the bottom of the rafters will make a Huge difference in room comfort by just stopping warm air from rising above the rafters.
Those heaters look like they are designed to mount up near the ceiling, but personally, I don't like the idea of any open flame heater in a space where I work on fueled vehicles.
These style heaters mount within an inch of the ceiling and are rated for garage installation. But I understand your safety concern.
Thanks,
