Oil/grease conversion data
   / Oil/grease conversion data #2
What are you using it for, Jay? :confused: I'm guessing that grease would have different, application-specific, additives than gear oil...
Neato chart, tho...
Neato chart, tho...
Maybe, but who cares - lube is lube. I'm putting it in the "transmission" (and I use that term loosely) for my 80's vintage Snapper LT16 lawn tractor. The transmission is a simple differential and reduction gear w/ chain-drive. Truth be told, I could put anything in there and it would work just fine. Using something with the same viscosity as specified is a bonus.
I'm using the tractor specifically for running a snowblower attachment to clear a driveway - I figured the gear oil would be better in the cold than grease.
JayC
   / Oil/grease conversion data #4
Good luck - your right about the lub qualities, but you will be lucky if that 85 wt oil stays in it. Snapper "00" grease is MUCH thicker than 85 wt oil.
I am not familiar with the Snapper model you have but the 85 wt oil will leak out of the Snapper models I have had experience with.
2023 DOOSAN DL220-7 WHEEL LOADER (A52706)
2023 DOOSAN...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
JOHN DEERE 7210R TRACTOR (A51247)
JOHN DEERE 7210R...
2015 International 4400 SBA Gap Vac Truck (A53117)
2015 International...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2021 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A54313)
2021 FREIGHTLINER...
